6 members (homer52, TrknGMC, Ponchogl, klhansen, Robert Crandall, Hotrod Lincoln), 37 guests, and 3 robots.
Topics128,023
Posts1,055,371
Members48,420
#1319824 07/30/2019 4:06 PM
I'm planning to replace the horn button on my '53 3100. How do you get it off, just pry it? Thanks!
~Denny
1953 Chevy 3100
w/1960 261 cid, 848 head | Weber 32/36 progressive 2 barrel carb. | Three on the tree & 3:55 torque tube | 12 V w/Gener-Nator & 6 V starter
1998 Chevy Suburban 350 ci awd/4wd
You should be able to pry it off with a flat screwdriver at the top. Go slow and steady so you don't mar the steering wheel.
Sounds good. I'll give it a go. Thanks
~Denny
1953 Chevy 3100
Update: I bought the replacement horn hutton but it's light weight & the base color behind the "Chevrolet" & 3 horizontal bars doesn't match the deep champagne color on the original. So I used a brush on my Dremel with some chrome polish (and some time) & cleaned off all the rust & corrosion. The chrome still looks pitted but it's shiny & I think it looks better than the $50 new button - which I returned. FYI
~Denny
1953 Chevy 3100
~Denny
1953 Chevy 3100
Good for you
Craig
Do you have "the deep champagne color of the original" on your interior currently?
Yes, that's the interior color so the original matches best.
~Denny
1953 Chevy 3100
Moderated by  ndkid275, Phak1
