| | | Forums66 Topics128,024 Posts1,055,392 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2014 Posts: 164 'Bolter | | 'Bolter Joined: Nov 2014 Posts: 164 | I'm planning to replace the horn button on my '53 3100. How do you get it off, just pry it? Thanks!
~Denny 1953 Chevy 3100 w/1960 261 cid, 848 head | Weber 32/36 progressive 2 barrel carb. | Three on the tree & 3:55 torque tube | 12 V w/Gener-Nator & 6 V starter In the Gallery Forum1998 Chevy Suburban 350 ci awd/4wd | | | | | Joined: Mar 2010 Posts: 10,271 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,271 | You should be able to pry it off with a flat screwdriver at the top. Go slow and steady so you don't mar the steering wheel.
| | | | | Joined: Nov 2014 Posts: 164 'Bolter | | 'Bolter Joined: Nov 2014 Posts: 164 | Sounds good. I'll give it a go. Thanks
~Denny 1953 Chevy 3100 w/1960 261 cid, 848 head | Weber 32/36 progressive 2 barrel carb. | Three on the tree & 3:55 torque tube | 12 V w/Gener-Nator & 6 V starter In the Gallery Forum1998 Chevy Suburban 350 ci awd/4wd | | | | | Joined: Nov 2014 Posts: 164 'Bolter | | 'Bolter Joined: Nov 2014 Posts: 164 | Update: I bought the replacement horn hutton but it's light weight & the base color behind the "Chevrolet" & 3 horizontal bars doesn't match the deep champagne color on the original. So I used a brush on my Dremel with some chrome polish (and some time) & cleaned off all the rust & corrosion. The chrome still looks pitted but it's shiny & I think it looks better than the $50 new button - which I returned. FYI
~Denny 1953 Chevy 3100 w/1960 261 cid, 848 head | Weber 32/36 progressive 2 barrel carb. | Three on the tree & 3:55 torque tube | 12 V w/Gener-Nator & 6 V starter In the Gallery Forum1998 Chevy Suburban 350 ci awd/4wd | | | | | Joined: Jan 2002 Posts: 2,839 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,839 | Good for you
Craig My '50 Chevy 3100 5 window, '62-235cu, 3:55 rear My truck ....... Respect The Rust If I'm not working on my truck, '65 m00stang or VW camper, I'm fishing with the wife or smoking Salmon.
| | | | | Joined: Mar 2010 Posts: 10,271 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,271 | Update: I bought the replacement horn hutton but it's light weight & the base color behind the "Chevrolet" & 3 horizontal bars doesn't match the deep champagne color on the original. So I used a brush on my Dremel with some chrome polish (and some time) & cleaned off all the rust & corrosion. The chrome still looks pitted but it's shiny & I think it looks better than the $50 new button - which I returned. FYI Do you have "the deep champagne color of the original" on your interior currently?
| | | | | Joined: Nov 2014 Posts: 164 'Bolter | | 'Bolter Joined: Nov 2014 Posts: 164 | Yes, that's the interior color so the original matches best.
