0 members (),
128
Mod | | | Forums66 Topics128,167 Posts1,057,021 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2010 Posts: 114 'Bolter | | 'Bolter Joined: Nov 2010 Posts: 114 | I've installed T5 in my 42 3/4 ton Chevy (running a 1962 235 6 cyl). While this is a major improvement over the OE Muncie 4 speed, it still leaves some things to be desired. The 3/4 ton's stock 4.55 R&P set makes 1st gear pretty useless although, the truck is far better at highway speeds. I'd like to swap out the R&P set to something closer to 3.90 or 4.10, in order to take care of the low speed acceleration. Can anyone tell me if they've done this in an Art Deco 3/4 ton? I did read the tech article about the 1955-62 pumpkin swap but, why change the whole pumpkin & mod the driveshaft just to swap the R&P ratio? If a replacement gear set in the 3.90 or 4.10 ratio is available for the 41-46 3/4 ton, I'd sure like to know about where to get a set. Thanks for any help or sources you have.
Ghost Rider Little Egg Harbor, NJ 1942 Chevy 3/4 ton pickup, 1962 235, Offy intake, Fenton headers, Dual Carter YFs, 1984 T5 1956 Chevy 3100 Apache, 67 350SBC, Saginaw 4 speed, 69 12 bolt
| | | | | Joined: Feb 2004 Posts: 29,868 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,868 | Running a T-5 in a 3/4 ton defeats the purpose of having a truck, so you might as well install some type of passenger car rear axle, also. High ratio gears for your stock rear end don't exist. Jerry
| | | | | Joined: Nov 2010 Posts: 114 'Bolter | | 'Bolter Joined: Nov 2010 Posts: 114 | I have all of the OE driveline on the shelf. I just got tired of being limited to 45 mph. BTW, the T5 came out of an S10, and it serves my purposes quite well. I'm not pulling stumps anyway.
| | | | | Joined: Jan 2000 Posts: 2,074 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 2,074 | Found a 4:11 ratio pumpkin from late 60s that dropped right into my 53 3600, not sure if same holds true for your 42. Late 60s 3/4 tons with automatic trans came with the 4:11s. Best of luck | | |
