6 members (Steelonsteel, dt235sd, Mike Burns, Youngin' Tut 59, Hotrod Lincoln, Hanks custodian), 65 guests, and 2 robots.
Topics128,066
Posts1,055,871
Members48,428
I need some help identifying this trannie that I recently bought. I bought it under the assumption that it was an SM420. I took it apart and noticed that ALL the gears were straight cut and there is no synchro! :confused: Here are a few pictures:
http://www.pirate4x4.com/forum/attachment.php?s=&postid=461967
http://home.off-road.com/~md11fr8dog/Graphics/SM420GearSet.jpg
http://www.pirate4x4.com/forum/attachment.php?s=&postid=459978
http://www.pirate4x4.com/forum/attachment.php?s=&postid=459464
Its by diganosed as a 1940-47 GM truck trannie, part #185 by someone else. The seller still insists that its an SM420, stating he got it out of a '50 GM 1 1/2 ton truck. Any advice? Anyone ever seen an SM420 with ALL straight cut gears and no synchro?
Sean
Steamboat Springs, CO
only one of your links worked, MD11Fr8Dog. I think you got screwed, man. is there a shift pattern on the shifter knob? heres what the sm420's shift pattern is.
[img]http://community.webshots.com/rz/r1/0/18/26/29701826YcXmvnLmyb_ph.jpg[/img]
The sm420 had syncros on 2nd, and third gear. Reverse and first were straight cut, and 4th is direct drive.
Get back to us soon. smile
Jonathan S. Keffer
Certified Yeti Trainer
Richard Roy Schlicht-
Good Grandfather, Veteran Wrench Turner...
"If it ain't broke, fix it 'till it is..."
Es gibt nichts, zu befürchten, aber befürchtet sich.
Sean , what you have is identical to the original box in my '40.
The gear lever has a wee lever to lift to get it into reverse. Definately no syncro.
A good tough box , but not an SM 420.
These were common in all the bigger '40 - '47 trucks , and optioned in the smaller ones
What are you planning on fitting it into ? .
Quote
Hmmm, they all worked for me!!
Not totally screwed, the seller has offered to buy it back. But I have to reassemble it, with no gaskets, and the case has been powerwashed and wirewheeled and all the internals have been carb cleaner dipped. This sucker is clean now!! frown
Yep, I have manual pages for the SM420, just trying to figure out with this thing is. The PO still thinks its anSM420 since it came out of a '50 truck! I asked how he was sure "its the originally trannie, after all, isn't that what we're doing??" wink
Sean
Quote
I was planning on using it in my 75 FJ-40 Land Cruiser with an early 3spd t-case and rebuilt original 2F inline 6. The grannie gear in the SM420, at 7.05:1 is about the lowest out there! [img]http://www.pirate4x4.com/forum/images/smilies/smokin.gif[/img]
Your observation confirms my friends research about it coming from a '40-47 truck!
Sean
Yup, it's not a 420, I have one in my truck, it's original, and it's a '50. 1st gear isn't synchro'd in the SM420, but the rest are, as you probably know. If you don't mind double clutching the crashbox you have is ok and probably stronger than the 420 but it will be a pain to drive on the street, loud, and is hardly worth anything- A real SM420 is probably worth 3 times as much. The pre-SM420 chevy 4speeds had the same ratios I think as the 420s but were not sychronised in 2nd-4th gears. The cases look almost the same in both of them but the shifter on the crashbox has a reverse lockout lever and the shifter on the SM420 doesn't. I suggest you either get your money back or use the tranny you have if you are not going to drive on the road and are good at double clutching. Have fun with your cruiser.
Paint & Body Shop moderator
Quote
Yep, sending it back to the seller, unless someone on this board wants it!! grin
Sean
