| | | Forums66 Topics128,057 Posts1,055,810 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#13207 04/11/2002 10:05 PM | Joined: Jul 2001 Posts: 140 Shop Shark | | Shop Shark Joined: Jul 2001 Posts: 140 | only one of your links worked, MD11Fr8Dog. I think you got screwed, man. is there a shift pattern on the shifter knob? heres what the sm420's shift pattern is. [img] http://community.webshots.com/rz/r1/0/18/26/29701826YcXmvnLmyb_ph.jpg[/img] The sm420 had syncros on 2nd, and third gear. Reverse and first were straight cut, and 4th is direct drive. Get back to us soon.
Jonathan S. Keffer
Certified Yeti Trainer
Richard Roy Schlicht- Good Grandfather, Veteran Wrench Turner...
"If it ain't broke, fix it 'till it is..."
Es gibt nichts, zu befürchten, aber befürchtet sich.
#13208 04/11/2002 10:15 PM | Joined: Feb 2001 Posts: 1,096 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 1,096 | Sean , what you have is identical to the original box in my '40.
The gear lever has a wee lever to lift to get it into reverse. Definately no syncro. A good tough box , but not an SM 420.
These were common in all the bigger '40 - '47 trucks , and optioned in the smaller ones
What are you planning on fitting it into ? . | | |
#13209 04/11/2002 10:25 PM | Joined: Apr 2002 Posts: 5 Member | | Member Joined: Apr 2002 Posts: 5 | Originally posted by gmcfan: only one of your links worked, MD11Fr8Dog.Hmmm, they all worked for me!! I think you got screwed, man. is there a shift pattern on the shifter knob? heres what the sm420's shift pattern is.Not totally screwed, the seller has offered to buy it back. But I have to reassemble it, with no gaskets, and the case has been powerwashed and wirewheeled and all the internals have been carb cleaner dipped. This sucker is clean now!! The sm420 had syncros on 2nd, and third gear. Reverse and first were straight cut, and 4th is direct drive.
Get back to us soon. Yep, I have manual pages for the SM420, just trying to figure out with this thing is. The PO still thinks its anSM420 since it came out of a '50 truck! I asked how he was sure "its the originally trannie, after all, isn't that what we're doing??" Thanks
Sean Steamboat Springs, CO
#13210 04/11/2002 10:31 PM | Joined: Apr 2002 Posts: 5 Member | | Member Joined: Apr 2002 Posts: 5 | Originally posted by Dusty: Sean , what you have is identical to the original box in my '40.
What are you planning on fitting it into ? . I was planning on using it in my 75 FJ-40 Land Cruiser with an early 3spd t-case and rebuilt original 2F inline 6. The grannie gear in the SM420, at 7.05:1 is about the lowest out there! [img] http://www.pirate4x4.com/forum/images/smilies/smokin.gif[/img] Your observation confirms my friends research about it coming from a '40-47 truck! Thanks
#13211 04/11/2002 10:41 PM | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | Yup, it's not a 420, I have one in my truck, it's original, and it's a '50. 1st gear isn't synchro'd in the SM420, but the rest are, as you probably know. If you don't mind double clutching the crashbox you have is ok and probably stronger than the 420 but it will be a pain to drive on the street, loud, and is hardly worth anything- A real SM420 is probably worth 3 times as much. The pre-SM420 chevy 4speeds had the same ratios I think as the 420s but were not sychronised in 2nd-4th gears. The cases look almost the same in both of them but the shifter on the crashbox has a reverse lockout lever and the shifter on the SM420 doesn't. I suggest you either get your money back or use the tranny you have if you are not going to drive on the road and are good at double clutching. Have fun with your cruiser.
#13212 04/12/2002 8:16 AM | Joined: Apr 2002 Posts: 5 Member | | Member Joined: Apr 2002 Posts: 5 | Originally posted by 4ontheFloor: I suggest you either get your money back or use the tranny you have if you are not going to drive on the road and are good at double clutching. Have fun with your cruiser. Yep, sending it back to the seller, unless someone on this board wants it!! Thanks
