5 members (GusG, Lightholder's Dad, Hotrod Lincoln, JoergK., fiz), 130 guests, and 1 robot.
Topics128,196
Posts1,057,386
Members48,469
#1320688 08/06/2019 3:41 PM
Had a crash box in my 46 1/2 ton. Besides lousy shifts, had what sounded like a rubbing noise under load. Just swapped to a 3 speed. So much better. But noise still there. There is play in front of drive shaft up and down. Time for an oakie bushing????
H Online: Content
Is the play there with the U joint installed on the drive shaft? If so, you need a bushing. It's normal for the shaft to move up and down if the rear half of the yoke is removed because the slip yoke is what centers itself in the bushing.
Didnt try it all hooked up.
