| | | Forums66 Topics128,192 Posts1,057,350 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2008 Posts: 127 'Bolter | | 'Bolter Joined: Apr 2008 Posts: 127 | Had a crash box in my 46 1/2 ton. Besides lousy shifts, had what sounded like a rubbing noise under load. Just swapped to a 3 speed. So much better. But noise still there. There is play in front of drive shaft up and down. Time for an oakie bushing???? | | | | | Joined: Feb 2004 Posts: 29,881 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,881 | Is the play there with the U joint installed on the drive shaft? If so, you need a bushing. It's normal for the shaft to move up and down if the rear half of the yoke is removed because the slip yoke is what centers itself in the bushing. Jerry
| | | | | Joined: Apr 2008 Posts: 127 'Bolter | | 'Bolter Joined: Apr 2008 Posts: 127 | Didnt try it all hooked up. | | |
