1 members (Peggy M),
95
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,101 Posts1,056,182 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2014 Posts: 106 Shop Shark | | Shop Shark Joined: Jun 2014 Posts: 106 | I couldn't find anything in a search. I hope this is the correct forum.
I need to pull the radiator out of Clyde ('37 1/2 ton) to have a leak repaired. Any tricks or tips to pulling it without removing the radiator shell?
Thanks in advance,
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Do you have a Shop Manual? I cannot find a 1937 Shop Manual on-line. 1938 Chevrolet Shop Manual | | | | | Joined: Jun 2014 Posts: 106 Shop Shark | | Shop Shark Joined: Jun 2014 Posts: 106 | | | | | | Joined: Jun 2014 Posts: 106 Shop Shark | | Shop Shark Joined: Jun 2014 Posts: 106 | It does have a similar write up. Thanks for the recommendation. I broke the cardinal rule and had not referenced the manual. Please for give me.  | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Good, Justin
There is nothing wrong with posting a question. | | | | | Joined: Feb 2000 Posts: 5,215 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,215 | Since my '37 has a 250 inch engine, I have to pull the thermostat housing and water pump to get radiator out. I never had the original engine, so have no idea how that works. Once I have the pump and housing out of the way, the radiator will come up and lay over the top of the engine, then slide it out under the hood supports. It would be easier to pull the hood off, but I have done it a couple times with hood in place. Once you drain coolant and unhook hoses, plug the outlets with caps or plastic bags and rubber bands. While the radiator is face down over the engine, it always seems to leak coolant on the fender and your legs as you menuver it out.
Joe | | |
