| | | Forums66 Topics128,143 Posts1,056,495 Members48,442 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2012 Posts: 158 Shop Shark | | Shop Shark Joined: Apr 2012 Posts: 158 | Recently picked up a 67 K20.. I immediately noticed below the openings of the cowl vent panel was packed with wet soggy leaves...I removed the panel, cleaned, washed, scuffed & painted to top of the cowl...Before I reinstall the vent panel, I want to put a screen to prevent anymore leaf build up...I have an idea of what to do, but was wondering if there was a fabricated aftermarket screen, or any idea's of what someone else did....I'm sure others have been down this road....Thanks | | | | | Joined: Apr 2002 Posts: 2,168 A teacher, but always an apprentice. | | A teacher, but always an apprentice. Joined: Apr 2002 Posts: 2,168 | Marauder, I had the same problem and I will likewise be making some sort of screen. I haven’t got to that bridge yet, but I do recall seeing an aftermarket screen somewhere. I’ll see what I can dig up if someone else doesn’t beat me to it.
Be thankful you just had leaves! Mine was so bad that the very bottom of that cowl recess down deep in front of the door was full of black dirt! Compost quality! I could had sprouted the best darn potatoes in that dirt. I couldn’t believe it. I wash and rinsed and washed and rinsed the bugger out of those areas. | | | | | Joined: Apr 2002 Posts: 2,168 A teacher, but always an apprentice. | | A teacher, but always an apprentice. Joined: Apr 2002 Posts: 2,168 | | | | | | Joined: Apr 2012 Posts: 158 Shop Shark | | Shop Shark Joined: Apr 2012 Posts: 158 | Seek & ye shall find.....Thanks for the link will order today !!! | | | | | Joined: Aug 2005 Posts: 277 'Bolter | | 'Bolter Joined: Aug 2005 Posts: 277 | I used a piece of "hardware cloth" epoxied to the inside of the panel. | | |
