0 members (),
136
Mod | | | Forums66 Topics128,193 Posts1,057,259 Members48,466 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2014 Posts: 1,293 Moderator for Tons o' Fun , Co-Moderator Driveline Forum | | Moderator for Tons o' Fun , Co-Moderator Driveline Forum Joined: Jul 2014 Posts: 1,293 | How can I identify an HO52 differential out of the vehicle? I have one located on the shelf, supposedly 68-72 vintage, has 10-41 on the ring gear What you are describing is an HO72 rear differential that can be swapped with the HO52 . To identify an Eaton 4:10 HO72 - Turn the carrier around where you can see the end of the pinion shaft on the pinion bearing end, the number 3934647 would be stamped there along with the 10-41 number. The stamping may be faint. The ring gear is stamped 3934641 on the flange with bolt holes, below the gear teeth. You may want a flashlight and a mirror to help view the ring gear stamped number. Ron
Ron - - Dusty53 1954 Chevy 3604In the Gallery Forum "You can't dance with the Devil and then wonder why you're still in Hell." "They will forget what you've said, and they will forget what you have done but they will never forget the way you made them feel." | | | | | Joined: Sep 2021 Posts: 4 Moderated | | Moderated Joined: Sep 2021 Posts: 4 | Ron - Thanks for the reply, new member here....I want to swap out the 4.57's in my 1948 3600 with a 4.10 unit from a 68-72 C or K20, as described in the article: https://www.stovebolt.com/techtips/axles/1%20Ton%20Upgrade/The article states the donor vehicles (3/4 tons) will have an HO52 gear set, but you say I need an HO72 set, can you explain - Thanks | | | | | Joined: Aug 2004 Posts: 1,418 ODSS Lawman | | ODSS Lawman Joined: Aug 2004 Posts: 1,418 | The axle in your truck, if original is an Eaton HO52. In order to perform this tech tip you need to purchase a HO72 rear pumpkin from a salvage yard. Pull the axle shafts and swap the pumpkins. It really is that simple....
SWEET Sergeant At Arms: Old Dominion Stovebolt Society BUNS?!?!?!Where we're going, we don't need no buns.....1950 GMC 450 1951 Chevy 1/2-TonThe GreenMachineIn the Stovebolt Gallery | | | | | Joined: Jul 2014 Posts: 1,293 Moderator for Tons o' Fun , Co-Moderator Driveline Forum | | Moderator for Tons o' Fun , Co-Moderator Driveline Forum Joined: Jul 2014 Posts: 1,293 | Ron - Thanks for the reply, new member here....I want to swap out the 4.57's in my 1948 3600 with a 4.10 unit from a 68-72 C or K20, as described in the article: https://www.stovebolt.com/techtips/axles/1%20Ton%20Upgrade/The article states the donor vehicles (3/4 tons) will have an HO52 gear set, but you say I need an HO72 set, can you explain - Thanks Sweet has answered your question. The part numbers I provided are for the pinion and ring gears for an HO72 carrier to help you identify the "pumpkin" you were referring to.
Ron - - Dusty53 1954 Chevy 3604In the Gallery Forum "You can't dance with the Devil and then wonder why you're still in Hell." "They will forget what you've said, and they will forget what you have done but they will never forget the way you made them feel." | | | | | Joined: Sep 2021 Posts: 4 Moderated | | Moderated Joined: Sep 2021 Posts: 4 | Quoting from the article: "The desired (for this upgrade) 4.10 ratio is only found in the HO52 axles used 1968-1972 (3/4-ton trucks with the 350/auto trans combo) To go faster, remove your old HO52 or HO72 center carrier (complete) and replace it with a complete center carrier from a 1968-1972 HO52 axle from a Chevrolet C-20 with a 350/auto trans."
According to this, I need an HO 52, not HO72.... | | | | | Joined: Jul 2014 Posts: 1,293 Moderator for Tons o' Fun , Co-Moderator Driveline Forum | | Moderator for Tons o' Fun , Co-Moderator Driveline Forum Joined: Jul 2014 Posts: 1,293 | LT 33 - from the same article, at the top, third paragraph - " In fact, this upgrade works for any truck with an Eaton HO52 or HO72 axle (3/4 or 1-ton trucks, 1947 -1972!" Lets found out what you've found - I suggest you take a look at the carrier you've found and provide at least one part number off the ring gear or the pinion gear and I'll research it for you and provide the information on what you have found. Note, an HO72 carrier ( pumpkin ) will definitely fit your application. Many bolters have made this swap. Suggest you PM John Millman and or Denny Graham, two of the authors, and ask for verification if that will help.
Get me those part numbers.
Ron
Ron - - Dusty53 1954 Chevy 3604In the Gallery Forum "You can't dance with the Devil and then wonder why you're still in Hell." "They will forget what you've said, and they will forget what you have done but they will never forget the way you made them feel." | | | | | Joined: Sep 2021 Posts: 4 Moderated | | Moderated Joined: Sep 2021 Posts: 4 | Thanks, waiting to hear back from the scrap yard and will let you know | | | | | Joined: Aug 2022 Posts: 11 'Bolter | | 'Bolter Joined: Aug 2022 Posts: 11 | The axle in your truck, if original is an Eaton HO52. In order to perform this tech tip you need to purchase a HO72 rear pumpkin from a salvage yard. Pull the axle shafts and swap the pumpkins. It really is that simple.... So I have a 58 1-ton dually with 5.14 gears I believe it's a HO72. I also have a 68 3/4 ton 4.10 posi rear end out of a 350/350 truck I believe I have a HO52. I can swap the 3rd member out of the HO72 for the HO52?? Brakes....will I need to find brakes for my HO72 1-ton dually from another newer 14 bolt dually? OR will a SRW 14 bolt brakes work as well?? Reason I ask the brake question is I have a SRW mid 80's 14 bolt 4.10 rear end out of a 3/4 ton. | | | | | Joined: Jun 2024 Posts: 26 'Bolter | | 'Bolter Joined: Jun 2024 Posts: 26 | In my quest to find a gear set to replace the HO72/5:14s I MAY have struck gold? Found a '70 3/4 ton with coil sprgs. but when I looked in the cab my heart sunk, it had a manual trans. Eng is gone but it appears to have been a small block. I've read that some coil versions could be 4:10. Does anyone have any experience on the subject? Thanks
1948 1 ton
| | | | | Joined: Sep 2009 Posts: 6,024 Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT | | Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT Joined: Sep 2009 Posts: 6,024 | Pick1, Check the glove box door for a decal with the build codes of the truck. One of those should ID the axle installed. If you can take a pic and post, folks here may be able to help decide the sticker to ID the axle in question.
~ Dan 1951 Chevy 3 window 3100Follow this story in the DITY Gallery"My Grandpa Carl's Truck and How it Became Mine"1966 Chevelle (Wife's Hot Rod) | 2013 Chevy Silverado (Current daily driver) US Army MSG Retired (1977-1998) | Com Fac Maint Lead Tech Retired (1998-2021)
| | | | | Joined: Jun 2024 Posts: 26 'Bolter | | 'Bolter Joined: Jun 2024 Posts: 26 | Gdads51, I'll have to return in the spring. The wrecking yard currently has a nice layer of white stuff ( yep, even in AZ) plus the owner has his hands full running a towing business. Thanks
1948 1 ton
