2 members (VicZ, oldsteve), 123 guests, and 1 robot.
Topics128,087
Posts1,055,974
Members48,430
#1320215 08/02/2019 10:56 PM
My gas gauge on my '54 6100 12 volt conversion is not working. It always registers 1/2 a tank. At first, it was the float as it had a hole in it. I thought that I had that fixed but now it registers empty all the time. I decided to change out the send unit. It still says empty. Does the attached photo look correct on the sending unit? If so, it's on to getting a new gas gauge.
kclark2227 #1320220 08/02/2019 11:07 PM
Sounds like you have a mismatch between the gauge and sender. The '54 should have a 0-30 ohm system, 0 ohms at empty, 30 ohms at full. If this is good, the gauge may be bad.
Mac :{)
1962 K10 short step side, much modified for rally
1969 T50 fire truck, almost nos, needs a few things
sweepleader #1320221 08/02/2019 11:13 PM
How can I check that properly?
kclark2227 #1320224 08/02/2019 11:17 PM
AD Addict & Tinkerer
It looks like your resister may be mounted in the wrong place. My resister is mounted on the positive lead going to the gauge from the ignition switch, cutting the voltage so the gauge doesn’t see 12 volts. Your picture shows a resister mounted on the wire going from the gauge to the sending unit so your gauge see 12 volts then gets cut down to protect the sending unit. You may have burnt out the original 6 volt gauge so that may be why it is not registering.
Phil
Project Journals
Stovebolt Gallery Forum
Phak1 #1320226 08/02/2019 11:20 PM
Can you post a photo of yours so I can see how it should look?
kclark2227 #1320231 08/02/2019 11:45 PM
Insomniac
Insomniac
Gord 🇨🇦
1954 1/2 ton 235 4 speed
kclark2227 #1320235 08/03/2019 12:09 AM
Insomniac
Insomniac
At the sending unit, after removing the runtz ("resistor") you should have two wires. Connect the brown wire that goes to the gauge to the center post. Attach the ground wire (white wire that runs to body) to one of the sender mounting screws.
Gord 🇨🇦
Gord&Fran #1320243 08/03/2019 1:35 AM
I'll try that out tomorrow, Thanks.
kclark2227 #1320317 08/03/2019 9:20 PM
How does one remove the gauge from the dash?
kclark2227 #1320324 08/03/2019 10:44 PM
Insomniac
Insomniac
You shouldn't have to take the gauge out. Pop the seat out to give yourself more room to work. I put a plank down to lie on while under the dash. Disconnect the hot wire from the gauge and install the runtz. The hot wire attaches to the other end of the runtz. The black wire that comes out of the runtz connects to ground - probably can connect it to one of the screws that holds the cluster to the dash.
Gord 🇨🇦
Gord&Fran #1320334 08/04/2019 12:30 AM
I believe that I need to replace the gauge itself as well. It seems to be totally dead.
kclark2227 #1320349 08/04/2019 3:39 AM
Insomniac
Insomniac
First thing I would do is test to confirm gauge is fried:
https://www.fillingstation.com/articles/fuelgaugetesting.htm
Removing cluster has been discussed on this forum before (e.g.):
https://www.stovebolt.com/ubbthreads/ubbthreads.php?ubb=showflat&Number=1008359
Gord 🇨🇦
kclark2227 #1320853 08/07/2019 12:32 PM
If you do have to replace the gauge, you can buy a 12 volt version so you won’t have to mess with a Runtz (resistor) anymore. I just ordered one from Classic Parts. This one is for a 54’.
https://www.classicparts.com/1954-55-1st-Fuel-Gauge-12-Volt/productinfo/24%2D725B/
Phil
Project Journals
kclark2227 #1321344 08/10/2019 6:36 PM
1 Offline
I went through this drama a few years ago, including installing a Runtz that worked very well; until a few years later after the introduction of alcohol in the gas. I thought the Runtz had failed. By this time 12V gas gauges were available for 47-53 trucks so I installed one. The gauge still read low - never over 1/2 tank. So I bought a sending unit and installed it. Gauge never moved at all after that - stayed at 3/4 no matter what. So I took the sender out and examined it closely. I discovered that the hole pattern on the sender caused the float to jam against the side of the tank. So I got out the old sender and looked at it carefully, measured the ohms, yep 30 ohms like its supposed to be. Hmmm, the cork float seems heavier that I would expect. Put the cork in a can of gas and watched it sink toward the bottom.
So I put the old sender back in with the brass float off the new sender in place of the cork one. Gage has read correctly ever since. After the cork float had dried out it floats once again but it'll stay in the parts box with the new mis-drilled sending unit.
1951 3800 1-ton
In the DITY Gallery
kclark2227 #1321399 08/11/2019 2:37 AM
Crusing in the Passing Lane
If one thins epoxy with acetone, soaks a dry float in it, it will become revaltized.
Ed
kclark2227 #1329168 10/07/2019 11:17 PM
I just bought a 12v gas gauge. I have the old one out. I know which cable is my sending unit and which is the power so I'm good there. My question is when I install the new gauge, nothing goes behind it before I seat it in the cluster correct? Also I put the "board" piece that says sender and power on the backside of the cluster case before putting on the washers, lock washers and nuts. Is that it? I had a cardboard jumper on the old one but that doesn't seem to be needed.
kclark2227 #1329199 10/08/2019 11:36 AM
I just installed a 12v fuel gauge I purchased from Classic Parts and installed nothing between the gauge and the cluster back. From what I’ve read in this forum, the gauge is grounded by touching the back of the cluster housing. The rectangular insulator I installed on the outside of the cluster under the flat washers, insulating the connectors from touching the cluster back and grounding out.
Mine now work perfectly! I hope I didn’t just jinx myself!
Phil
Phil
Project Journals
