7 members (wilbur53, 1955 1 Series, SmalltownTRKGuy, Jon G, ShopRag, Southerntruck, 60steve), 113 guests, and 3 robots.
Topics128,212
Posts1,057,468
Members48,471
I have a 1937 Chevy 1/2 ton pickup that has sheet metal welded to the bottom of each seat. Since it was done so poorly, I have to believe that it was an attempt to keep out the mice and bees, rather than an attempt to fix an actual problem.
I also found small pieces of window screen stuff into each open hole in the cab. Again, I'm assuming he didn't like bees in his truck.
Should the underside of the seat be open normally? Or should there be some sort of metal pan on the seat base?
Thanks for your time.
Read the article from Jim Carter...
http://oldchevytrucks.com/blog/inde...hevrolet-gmc-gas-tank-and-seat-cushions/
You need to read the whole article and see the addendum at the end. They are not sure what is original for the bottom of the seats. It is also possible that different factories finished the seat bottoms differently. I found my seat bottoms in a junk yard and were not in good condition, so I can't add any information.
Kent
1937 Chevy 1/2 ton
1942 Chevy 1/2 ton
1947 Diamond T Model 509
1951 Chevy 1/2 ton
Moderated by  ndkid275, Phak1
