6 members (greenie-reddy, GMCJammer51, 2-Ton, 3B, 55shaker, JW51), 94 guests, and 0 robots.
Topics128,154
Posts1,056,834
Members48,456
Which middle brace can I use on a 1940 Chevy pickup,with Safari windshield. I have a Fulton series 800 sunvisor.
Haunting the SBP since 2001
Fulton made a special center sandwich & roof mounting system for that application.
I have seen that before, but the roof on the truck is not flat. It has a peak in the middle. I wonder if that roof bracket can be bent in the middle to accommodate for that?
Fulton also offered a cowl center mount that connected to the under side of the visor & the top of the cowl.
Do you have a roof mount Fulton bracket and a Fulton visor for sale ? I can't find a good one on flea bay. Your help appreciated.
I am shocked that a moderator has not already stepped in here but...offers to buy & sell are not allowed in the general forums.
You will need to post a wanted ad in the swapmeet section or use private messages.
Thank you M/T for helping folks obey the rules. Hopefully thrift_master will get the hint and send you a PM.
