5 members (BC59, Danielbolt, Otto Skorzeny, Rusty Heaps, Peggy M), 104 guests, and 2 robots.
Topics128,093
Posts1,056,480
Members48,444
#1319791 07/30/2019 11:41 AM
Have a 54 1/2 ton P-U and trying to determine the big pinion nut size prior to me tearing into the diff.
' Offline
I may be wrong but it's a good possibility
this would be your Pinion Nut .
Measure the nut ........it would be 1 & 1/8 " .
If it's smaller........I have another possible pinion nut .
PIC
https://i.postimg.cc/W3xvSsV2/Pinion-Nut-Rear-Axle.jpg
George
'54 3600
1954 3600
Now cruising in
The Passing Lane
George,
I may have used the wrong wording but it is the but it is the big nut on the pinion shaft inside the differential that is peened over to keep it in place.
ODSS Lawman
ODSS Lawman
I believe George is correct. If it’s the same size as a β€˜51 which is 1 1/8” for sure.
SWEET
1950 GMC 450
1951 Chevy 1/2-Ton
The GreenMachine
Gentlemen, thanks for the help.
Crusing in the Passing Lane
If the issue is to have the correct size socket before hand, hock shops usually have a good assortment of single sockets to avoid having to buy a set.
Ed
ODSS Lawman
ODSS Lawman
The pinion is pretty long. I think a wrench which can also be had at the same place would be best.
SWEET
1950 GMC 450
1951 Chevy 1/2-Ton
The GreenMachine
