2 members (1955 1 Series, Otto Skorzeny), 127 guests, and 3 robots.
Topics128,094
Posts1,056,465
Members48,443
#1319266 07/26/2019 2:20 AM
I bought this pan a few years back for a 216 project, took it out of box for a quick look and put it back on the shelf. Now after awhile I finally take a good look at this pan and wonder what I bought? NO drain fitment and the ends of the pan that would mount to the front and rear caps have no reinforcement tabs.
Do I have a nice Expen$ive box or a pan that really fit something.
Expen$ive Box
There is not a tool made that if you don't try hard enough you can't break!
1952 3100 261 T5 3.08 Gov Locker
Rustnut #1319267 07/26/2019 2:23 AM
Ooops, the 261 some how elbowed it's way into the alblum.
Rustnut #1319271 07/26/2019 2:45 AM
Check "chevy.oldcarmanualproject.com" The P/ N on box crosses to an oil pan for all 53 engines except power glide. Don't know why no drain plug hole or reinforced ends.
Ed
Rustnut #1319318 07/26/2019 2:22 PM
COULD OF BEEN PUT BACK INTO THE WRONG NOS BOX AT THE DEALERSHIP 60 YEARS AGO.
1953 Chevrolet 3100
In the DITY Gallery
Video of the 261 running
1964 GMC 1000
sstock #1319355 07/26/2019 7:44 PM
Yep, Or maybe it survived because it was defective. The mechanic pulled it out of the box, saw the lack of drain plug and reinforcement, put it back in the box and threw it in the corner.
Rustnut #1319360 07/26/2019 8:55 PM
Its missing a lot more than just a drain plug. It should have the gutters and spray nozzles.
Rustnut #1319375 07/26/2019 10:45 PM
Here are somo photos of a 216 oil pan for 1939- 1946.
Harold
Harold
Rustnut #1319439 07/27/2019 2:06 PM
Except for the missing drain, that pan would work will on someone's 1953-54 full pressure 235, as they had the same bolt pattern and did not use dipper troughs.
My Blog
