7 members (Thomaslb, 1955 1 Series, Hanks custodian, Ridgeback, Hotrod Lincoln, Ponchogl, 1 invisible),
46
Mod | | | Forums66 Topics128,090 Posts1,056,031 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2018 Posts: 34 'Bolter | | 'Bolter Joined: Aug 2018 Posts: 34 | The driver door is stuck closed. Can't take the interior panel off to get at the mechanism. The handles inside and out are well connected and seem to ber partially move the mechanism that opens the door. Is there a way to trigger the opening mechanism from above? Through the gap bertween the window and door? I can see some of the mechanism, can it be triggered by pushing down or pulling up? | | | | | Joined: Dec 2014 Posts: 678 'Bolter | | 'Bolter Joined: Dec 2014 Posts: 678 | You share the last name of the aftermarket door latch manufacturer. Ironic.
When my 51 panel door was stuck shut someone advised slamming into it from the inside with my shoulder as hard as I could. I was skeptical, but it worked.
And why can't you remove the interior door panels?
1951 Chevy Panel Truck
| | | | | Joined: Sep 2011 Posts: 39 'Bolter | | 'Bolter Joined: Sep 2011 Posts: 39 | Had the same problem with my '49. It was locked and wouldn't unlock with the handle or the key. I was able to get the interior panel off (wasn't real easy) and was able to trip the lock mechanism with a screwdriver. The main problem was my door was out of alignment. | | |
