5 members (DoubleB, EchoBravoSierra, frogfarmer, TooMany2count, Achipmunk), 55 guests, and 1 robot.
Topics128,090
Posts1,056,024
Members48,432
#1319223 07/25/2019 8:31 PM
The driver door is stuck closed. Can't take the interior panel off to get at the mechanism. The handles inside and out are well connected and seem to ber partially move the mechanism that opens the door. Is there a way to trigger the opening mechanism from above? Through the gap bertween the window and door? I can see some of the mechanism, can it be triggered by pushing down or pulling up?
'48 Panel
You share the last name of the aftermarket door latch manufacturer. Ironic.
When my 51 panel door was stuck shut someone advised slamming into it from the inside with my shoulder as hard as I could. I was skeptical, but it worked.
And why can't you remove the interior door panels?
1951 Chevy Panel Truck
Had the same problem with my '49. It was locked and wouldn't unlock with the handle or the key. I was able to get the interior panel off (wasn't real easy) and was able to trip the lock mechanism with a screwdriver. The main problem was my door was out of alignment.
