5 members (dt235sd, Otto Skorzeny, UtahYork, klhansen, mk72), 46 guests, and 1 robot.
Topics128,053
Posts1,055,776
Page 3 of 3 1 2 3
tclederman #1317881 07/16/2019 2:43 AM
Mike, or others, is my photo wrong for the head casting code?
A 17 9 (head date casting code)
A = January
17 = 17th
9 = 1949
Tim, I can't help with casting number locations on 6-cylinder heads...sorry, but the date code you decoded is correct.
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
Dcurtis #1317882 07/16/2019 2:50 AM
Originally Posted by Dcurtis
but is it possible that this head is a replacement?
I don't think it's a replacement with a Jan 1949 cast date.
Curious to know why you think it could be a replacement?
Mike B smile
Mike Boteler
1984 Jeep CJ7
Silver Spring, MD
Dcurtis #1317996 07/16/2019 9:38 PM
Well I don’t necessarily think it’s a replacement head. Just was thinking maybe it could be since the casting numbers are missing. But no worries! I spent some time and 10 cans of carb cleaner and cleaned up the valve train and top of the head of all the sludge and 70 years of buildup. I found the casting numbers 3835409
Dan
Dcurtis #1318002 07/16/2019 10:03 PM
3835409 = 1949 216/235 head
Dcurtis #1318003 07/16/2019 10:12 PM
2 Offline
head casting 3835409 is used in part # 3835408 for 1949 engines and listed as replacement head for all engines 41-49 216 and 235 engines as of 1949, in 1950 a newer replacement head is listed in place.
This head has non-45 degree exhaust valves, compatible if swapping whole head assembly w/ valves
This head has 14 mm spark plugs, but may have been machined for 10 mm spark plugs in early years, not sure.
Dcurtis #1318186 07/18/2019 3:02 AM
Ok on to the next step with this new engine! Cleaned the valve train oil has been changed the fuel pump is working there’s spark but no start! This engine has a carter w-1 carburetor on it I have a Rochester on the original engine. It is my understanding that the w-1 isn’t the best carb ! Is that correct? I think in in need of a carb rebuild kit so what carb should I be rebuilding? The Rochester or the carter.
Dan
Dcurtis #1318189 07/18/2019 3:21 AM
Will it run with a little gas poured into the carb? It should at least kick a few times if you have spark and the timing is close...
Mike B smile
Mike Boteler
1984 Jeep CJ7
Silver Spring, MD
Dcurtis #1318226 07/18/2019 12:39 PM
Are you 100% sure your timing is right?
Dcurtis #1318266 07/18/2019 5:19 PM
I’m not 100% sure of anything!!! Maybe it was just a illusion but I thought I saw spark I checked again this morning there’s no spark everything looks like it’s hooked up properly so maybe bad coil or condenser? Either way it turns over great going to get a compression tester to check the compression and order a new ignition system from Langdon’s going to get a carb kit to but still not sure if I should rebuild the carter of the Rochester? Any opinions on that ?
Dan
Dcurtis #1318274 07/18/2019 5:59 PM
No spark or questionable spark, I always clean the points with a points file, (available at NAPA or anywhere parts are sold), and then set them to factory specs. If the distributor has not been moved in recent history, I would leave the timing alone to see if the engine would run. If spark is good but no fire, I would prime the carb with a couple tablespoons of gas right down the throat (like Mike said ^), close the choke and crank. IF spark is bad, then I would go for new parts.
Mac :{)
1962 K10 short step side, much modified for rally
1969 T50 fire truck, almost nos, needs a few things
Dcurtis #1318328 07/19/2019 1:56 AM
I pulled the Rochester off the seized engine this evening to clean it up and check out its condition this was under it attached to the manifold. What is it ?
Dan
Dcurtis #1318330 07/19/2019 2:06 AM
Governor, will have a tube to the distributor.
Mac :{)
Dcurtis #1318408 07/19/2019 5:27 PM
Well I wonder what purpose it served on there ?
It seems the Rochester carb from the 50 is probably not any good the throttle shaft is seized in the carb body. I’ve had it soaking in mineral spirits in my parts cleaner since yesterday. I will probably give it a few more days before I give up on. The carter also is nearly seized the throttle shaft and the choke are very stiff I may be able to get them freed up thou. If I have to get a new carb it seems there’s plenty of options available but I’m wondering what you guys that have had to replace yours have tried
Dan
Dcurtis #1318418 07/19/2019 6:12 PM
If it was my carb, I would be tapping on the shaft to try to get it to move. That is exactly what I had to do with the carb on my '62 when I let it sit long enough for the mice to build a nest. I would pull the throttle plate if I could get at the screws to grind the back end off, they are peened to prevent them falling into the engine. I would tap the shaft endwise and sideways all around and both ends. The rust/corrosion usually yields to physical force but of course so do the shaft and the bore it goes through, use caution.
Mac :{)
Dcurtis #1318422 07/19/2019 6:45 PM
The bore is exactly what I was worried about ! If it’s corroded so bad I can’t move it at all the bore is already going to be damaged. I don’t have a drill press good enough to drill for bushings. Maybe it’s time to acquire a new pedestal drill press!!
Dan
Dcurtis #1318424 07/19/2019 6:47 PM
I do definitely plan on dissecting it thou. Even if I can’t save it I always love learning how things work
Dan
Dcurtis #1318430 07/19/2019 7:13 PM
Just because it is stuck does not mean that automatically the bore is bad. It could be stuck in one small place and the rest could be fine. Check it out before you plan on it being bad.
The governor limited the top engine speed to something like 3500 or 4000 rpm to prevent running it too fast with a very deep rear end gear. Check the base of the distributor for the vacuum control that feeds the servo under the carb. The governor is really not needed if you watch the engine speed, something that employees driving someone else's truck and paid by the load tend to do poorly at. The governor throttle plate is visible in the pictures, it is independent of the manual throttle in the carb.
Mac :{)
Dcurtis #1318433 07/19/2019 7:46 PM
The throttle plate on the governor is free too ! However there is nothing attached to it. I will take a better look at the distributor to see if there’s anything extra on it !
Dan
Dcurtis #1318594 07/21/2019 1:53 AM
Well after a long soak in mineral spirits then about an hour in the ultrasonic cleaner I was able to free the throttle shaft on the Rochester the whole thing is disassembled except 1 problem has arose. The jet is not coming out it is loose it just turns so it seems the threads are torn loose from the float bowl body. I don’t think there’s a repair for that is there ? Guess I’ll start working on the carter tomorrow see what I can do with that one.
What is the typical response time for langdons ? I put an email in last Wednesday about getting an hei ignition system from him and still haven’t gotten a reply. I guess I’ll try again Monday if I haven’t heard from him by then. I do believe he is located in my area but I can’t tell if there’s a storefront or if he’s just online
Dan
Dcurtis #1318596 07/21/2019 2:07 AM
586-739-9601 Monday-Friday 11am to 7pm EST
Dcurtis #1318599 07/21/2019 2:34 AM
Crusing in the Passing Lane
Now would be a good time to remove the valve cover, perhaps you already did, to oil all the valve stems and push down on them to make sure they are not stuck before you try to turn the engine over. If they are stuck, pushrods will be bent.
If stuck, soaking and gentle tapping will help, however, if the mice have been helping you out, it might take some gentle heating.
Good luck.
Ed
Dcurtis #1318713 07/21/2019 11:09 PM
After looking on the online diagram of the Rochester b I discovered I was wrong it isn’t the jet that was stuck it was the guide for the spring of the pump discharge ball I did get it removed but it is broken and I don’t see anywhere I can get a replacement. I’m going to email mikes carburetor parts if I can’t locate one because it seems like that’s the only thing holding me back from rebuilding the B. The power has been out at my place since yesterday from storms so I didn’t get anywhere on the carter today hopefully tomorrow!
Dan
Dcurtis #1326417 09/16/2019 9:07 PM
Things are moving slowly because of my work schedule and other obligations. I’m working on getting the engine stripped down to clean it and paint it. I’m thinking maybe I should replace the freeze plugs as they are at the least very old. Looks like the are available at many places who has had the best luck with what plugs ? Also I’m wondering if the governor is necessary? Can I remove it and be ok ? Or should I clean it up and reinstall it.
Dan
Dcurtis #1326418 09/16/2019 9:14 PM
1950 235 truck engine freeze plugs?
Rockauto.com?
Dcurtis #1326419 09/16/2019 9:20 PM
"Also I’m wondering if the governor is necessary? Can I remove it and be ok ? Or should I clean it up and reinstall it."
You should be able to remove the governor.
You might have to adjust carburetor linkage rods/etc.
Use a bakelite carburetor spacer and the correct gasket with opening in the gasket oritated to the opening on the base of the carb.
Wait to hear from a Big Truck owner - it has been a long while since I removed a governor,
Dcurtis #1326420 09/16/2019 9:26 PM
Tim the engine is a 1949 235. I did see the plugs on rock auto they are definitely the cheapest!
Dan
Dcurtis #1326422 09/16/2019 9:45 PM
The governor helps to keep you from over reving the engine when shifting up through the lower gears. If it works I'd keep it...
Mike B smile
Mike Boteler
1984 Jeep CJ7
Silver Spring, MD
Dcurtis #1326652 09/18/2019 12:02 PM
Mike- I’m not sure if it works or not. The butterfly moves freely. Not sure the condition of the inner workings. I guess I can just clean it up and reinstall it.
Thanks for the input !!
Dan
Dcurtis #1374450 08/22/2020 6:29 PM
It’s been a while since I’ve worked on the 50 but I have been collecting parts. Found out I’m missing the plug seals for the push rod cover. They were not included in the gasket set I bought for it. Where can I find the seals without buying another gasket set ? Maybe I haven’t looked hard enough but I can’t find them available separately.
Thanks Dan
Dan
Dcurtis #1374458 08/22/2020 7:28 PM
Dan, The Filling Station sells them individually: Spark Plug Cork Gasket.
1947 2nd-Series GMC FC152 3/4-ton
Follow the story in the DITY
1953 Chevy Bel Air Sport Coupe Powerglide
Dcurtis #1374462 08/22/2020 8:02 PM
Wow. I wonder why that wasn’t coming up in my searches. Thanks ordering them now.
Dan
Dcurtis #1375565 09/02/2020 3:43 AM
9
9 Offline
I thought this was a 235? The side cover doesnt go up onto head? So why do u need the 216 style seals?
Karl j Townsend
Page 3 of 3 1 2 3
