1 members (Paul Mullen), 99 guests, and 1 robot.
Topics128,089
Posts1,056,141
Members48,436
#1318350 07/19/2019 6:37 AM
We are installing a Newport Engineering electric wiper motor in a '49 3100. We do have the correct motor that clears the choke cable.
We have the motor installed and the wiper arms connected to the motor. It did take some work to get the mounting brackets in positions so that the wiper mounting screw holes were near the mid-position of the slots.
The problem we appear to have is that the rotating head on the motor travels so far that the 2 arms contact each other. They hit so hard that it forces the c-clips off the posts and the arms fall off the post.
I know there is some adjustment for the park position.
Is there an adjustment for travel during the operating cycle?
Thanks for the help!
Rusty
Here is a link to a previous installation (it has dead links in it tho), maybe one of those folks can help you out.
https://www.stovebolt.com/ubbthreads/ubbthreads.php?ubb=showflat&Number=713476&page=all
Another quality post.
Real Trucks Rattle
Thanks for the link. I had found post that through a prior search. Unfortunately the link to the install pictures is the only one that does not work. And I think that is the one we really need!
The truck owner is going to try to contact Newport this week.
Our latest assessment is that the amount of travel is not necessarily the problem. We are thinking we can eliminate the interference if we can simply reposition the "hub" on the wiper drive shaft.
Rusty
