3 members (Nick in Manitou, TooMany2count, klhansen), 120 guests, and 4 robots.
Topics128,109
Posts1,056,240
Members48,437
#1318345 07/19/2019 3:31 AM
Pete and Jakes sent me pictures of my front axle they had Super Bell make for me. My spindles are getting altered and when I get them back I will send them to them and they can finish it. It is super strong.
Crusty Old Sarge
Crusty Old Sarge
I have a 4 inch drop axel from Sid's in OK. I found that with 15 inch wheels the axel is the lowest point, not real good if you have a flat. After doing some figuring, if I use 17 inch wheels everything will clear. My only issue is that I wanted to run 15 inch raised white letter (RWL) tires, no one make a RWL in 17 inch. I have a set of pristine 15 inch Corvette Rallys. So I'm still looking at wheels... Nice Chrome .
~ Craig
1958 Viking 4400
"The Book of Thor"
Read the story in the DITY
1960 Chevrolet C10
"A Family Heirloom"
Fox Offline
I agree. That is very nice. Too nice for me. I would be scared to drive it! 😉
1970 Chevrolet C10
1950 Chevrolet 1-Ton Dually
"Ole Red Girl"
More pictures here
Parts trucks-
“Chrome don’t get you home”, but it sure looks good getting you wherever you’re going! Good score Mick. 🛠
Like tuts, I also did the 4” dropped axle with 15” rims. If I blow a tire my axle is 1/2 off the road. If the tire comes off the rim, my axle will become a plow. My front axle is roughly 4.5” off of the pavement. Double check your scrub line to ensure that you are good. PM me if you want pictures!
Chris
Chris
Not quite. Since drop axles are arced in the center, if your tire comes off the rim the opposite tire will still be supporting your axle on that side, tipping it up sufficiently to avoid ground contact on the flat side. Feel better now?
1951 Chevy Panel Truck
Crusty Old Sarge
Crusty Old Sarge
My axel is a factory OEM, Sid's heats and stretches the ends to the drop desired, once done it's again hardened. I may be looking a it differently but on mine the center seem lower than the ends. With a 235/60/15 I have about 3.5 - 4 inches of clearance. Either way it's plenty low, if I had to do it over I would have gone with a 2 inch.
~ Craig
1958 Viking 4400
"The Book of Thor"
1960 Chevrolet C10
"A Family Heirloom"
miracle,
A little better, but not too much! lol
Tuts,
I love the way mine looks, but I probably would have done a 3" drop instead.
Chris
Crusty Old Sarge
Crusty Old Sarge
Chris, Did you remove any of the leafs from the front springs? I removed 3 in hopes it would soften up the ride a bit, also added a sway bar front and rear.
~ Craig
1958 Viking 4400
"The Book of Thor"
1960 Chevrolet C10
"A Family Heirloom"
Tuts,
Originally, I removed half of the springs. After talking to everyone, I put them all back in! I also added a sway /anti roll bar to the front, which made a major handling difference! I am considering a steering dampener in the future.
Crusty Old Sarge
Crusty Old Sarge
What was the reasoning behind putting the leafs back in, stiffen up the front end? I am just putting the frame back together so not to far along to make any changes. I have MONROE GAS magnums for shocks.
~ Craig
1958 Viking 4400
"The Book of Thor"
1960 Chevrolet C10
"A Family Heirloom"
I had concerns about breaking a leaf spring. I talked to many old guys that talked me into putting them in. It rides just fine with all of them and I like the way it looks.
Chris
A tennis ball wont even roll under mine. 4" axle w/ 60 series tires.
Crusty Old Sarge
Crusty Old Sarge
Marty, just checked out your pics in the gallery. Love your wheel and tire combination. The truck doesn't look that low for a 4" drop axel.
~ Craig
1958 Viking 4400
"The Book of Thor"
1960 Chevrolet C10
"A Family Heirloom"
My truck was lowered 5" but on gravel roads, I scooped up gravel and then on the highway it would throw the gavel all over. My front end is a Pacer and in the rear is a lowered Nova rear axel.
Ron, The Computer Greek
I love therefore I am.
1954 3100 Chevy truck
2017 Buick Encore
See more pix
Crusty Old Sarge
Crusty Old Sarge
So now the question, how low is too low. The roads in the South aren't trill of pot holes and ruts like else where, but realalisticaly what's practical? The 59 is not going to be a show truck by any means, it days as a work horse are probably over too.
~ Craig
1958 Viking 4400
"The Book of Thor"
1960 Chevrolet C10
"A Family Heirloom"
The picture in the gallery is when my
54 was to low and plowed the gravel roads. It was immediately raised 2" when I got home.
2017 Buick Encore
See more pix
