0 members (),
107
Mod | | | Forums66 Topics128,265 Posts1,058,365 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#13178 08/12/2003 4:22 PM | Joined: Jul 2000 Posts: 962 Shop Shark | | Shop Shark Joined: Jul 2000 Posts: 962 | Hey guys
I had ordered a replacement for the cracked reed in my air compressor. Went back this past saturday and the shop guy says "Thats a non-replaceable part. You'll have to order a whole new compressor and motor assembly." Just as my heart sank into my shoes, he reaches under the desk and pulls out a replacement cylinder head and gives it to me. for free.
So I swap heads on my compressor, and now it buzzes right up to 125 psi and shuts off fine.
So I'm thinking this is a good omen for the weekend. Sunday morning I break out the 235 block and wash it down with hot water and soap. I wipe it out and fog with WD-40. Do the same to the crank. I put on my gloves and break out the main bearing shells.
Wrong main bearings. F#*# a duck.
So now I'm waiting on the correct mains for a '60 235.
the saga continues.
Preaching the Hot Rod Gospel according to the 4-stroke apostles:
Suck, Squish, Fire and Fumes
#13179 08/12/2003 6:01 PM | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | Chip, your luck might have been used up by that compressor head incident. Whatever y'all do, please don't come help me.  I'm now entering the sixth week of my one week project on my 69, disc brakes and lowering. Right now I'm waiting on the correct trailing arm bushings to come.
Fred 52 3600 69 C-10
#13180 08/12/2003 6:04 PM | Joined: Jul 2002 Posts: 358 Shop Shark | | Shop Shark Joined: Jul 2002 Posts: 358 | | | |
#13181 08/12/2003 6:37 PM | Joined: Jul 2000 Posts: 962 Shop Shark | | Shop Shark Joined: Jul 2000 Posts: 962 | something like that....
#13182 08/12/2003 7:44 PM | Joined: Feb 2001 Posts: 1,897 Member | | Member Joined: Feb 2001 Posts: 1,897 | Any way to adapt the compressor to the car,,, maybe power it on air
