1 members (Lightholder's Dad), 82 guests, and 2 robots.
Topics128,142
Posts1,056,491
Members48,442
#1317315 07/11/2019 4:04 AM
Hi all, I finally have the time and funds to start on my 1951 Chevrolet 3100. I have been reading the forum for a few years and still have a few questions.
1. This will be a daily driver when I’m finished so for my wife’s peace, is it wrong to put seatbelts in?
2. From what I have seen, should I pull the trigger and upgrade to 12-volts?
3. I would like to stay as original as possible, are there any other upgrades I should consider? It doesn’t have an engine but I was looking at the 235 CPI with single carb.
Any suggestions would be appreciated. The local community college has several automotive classes and encourages the students to bring in their projects and work on them–even on Saturdays.
Welcome to the Stovebolt madness. There is no cure! shake
The Welcome Center is really not the best place for questions. Why? Because only about 1% of our membership ever come back here after their introduction. Read through the various forums and pick out the best for each question. Multiple questions about different subjects in the same thread make it hard for those searching for a particular topic. Take some time to read the Sticky Thread at the top of the General Truck Talk Forum about “Why Posts are Moved, Edited or Deleted” for some good information on navigating the site. You’ve got a great fun project ahead.
In response to your items listed above:
1. By all means put in seat belts (shoulder straps can also be installed on both sides, unless you have a panel body truck).
2. Unless you need a lot of 12v high-power devices, 6v volt works reliably.
- have a good 6v battery
- make sure both the battery cables and all the grounding straps (usually braided) are 2 gauge or 1 gauge, or 0 gauge, or 00 gauge
(size matters - 2 gauge was original on 6v and 4 gauge was original in 12v)
- check/clean ALL grounding locations - poor grounds are the main problem causing complaints about 6v systems
3. Inexpensive 6v-12v converters are available, if you want to use a few low-power-draw 12v devices (like GPS or cell phone chargers)
I have had only one problem with 6v on my 1954 Suburban that I have owned/driven for 47 years.
That one problem was a combination of having a combination of 12v cable and a bad ground.
Have fun. Make sure you BAG and TAG all the parts, especially the hardware!! And like the others said, for a better response, please ask questions that apply to a particular forum in that forum.
Another quality post.
Real Trucks Rattle
Take lots of photos of parts before you take them apart.
Like Rusty Rod and tclederman have said BAG, TAG AND PICTURES. I just hired a new guy to work with me well he pulled a part one of my customers car and did not mark a thing and this is a total frame off. I have been looking for parts bolt screws etc for weeks. So take there advice.
Can't add much to what's already been said, except to say there is no "wrong" way to do anything! It's your truck-the only one you have to please is yourself.
Welcome to the Bolt!
Rich
1947 Loadmaster
1947 Chev. Loadmaster
1959 Chev. Viking 40
