| | | Forums66 Topics128,037 Posts1,055,467 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2002 Posts: 438 Shop Shark | | Shop Shark Joined: Sep 2002 Posts: 438 | Bolters-
I need help from you Chevy experts. I have set up my rig with a modified TH350 transmission, making it the same length as a 700R4. I found a stock driveshaft that would fit the standard TH350 to rear differential, approximately 55-1/2". Yet, with the modification, I need a driveshaft at 53-1/2". Does anyone know about the stock shaft lengths from a standard 700R4 so I can search the yards? Maybe a Monte Carlo? Is there a table on the net with driveshaft lengths? :confused: :confused:
Thanks in advance- | | | | | Joined: Feb 2000 Posts: 5,195 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,195 | Here are few listed in my Hollander exchange manual: 53-12/16" Jimmy Blazer 73-81 4x2 M.T. 4 spd 52-25/32" 73-81 van/truck 110"wb 6.6L Chev/GMC 52" weld to weld Cadillac 77-80 gasoline V8 53-13/64" 75-80 Granada/Monarch V8 8" ring gear 53-13/16" 73-78 Fury/Coronet/Monaco/Satalite 53-13/32" 63-70 Jeep truck 4x4 53-19/32" 74-77 F250 150"wb 4x4
Not all are marked with the length. You might find a GM car but you will have to measure them. The Blazer/Jimmy may be as close as you are going to get, but the yoke might not fit or interchange. Joe | | | | | Joined: Sep 2002 Posts: 438 Shop Shark | | Shop Shark Joined: Sep 2002 Posts: 438 | Thanks so much Joe! Wish I had a Hollander's at home! | | | | | Joined: Jul 2001 Posts: 6 Member | | Member Joined: Jul 2001 Posts: 6 | Another thing you could do is to find a drive shaft shop, most of these shops can make anything you want and will tell you how to measure for the shaft. I was able to have a shaft made for my 1955 GMC and I had it balanced. The shop I went to did everything from large trucks to 4 x 4 they had blank yokes which could be machined for your needs.
Dave | | | | | Joined: Sep 2002 Posts: 438 Shop Shark | | Shop Shark Joined: Sep 2002 Posts: 438 | dj-
thanks for this suggestion. I can certainly have a longer shaft machined. I was thinking that I could save money if there was a stock option. How much did sizing the saft set you back? I'll probably have any shaft out of the yard balanced to make sure it's right and reduce vibration. | | | | | Joined: Jul 2001 Posts: 6 Member | | Member Joined: Jul 2001 Posts: 6 | The only part I had was the spline for the Hydra-Matic trans. so the drive shaft was all new they machined the yokes, balanced and installed new universal joints. I was able to get a drive shaft length from a GMC parts book and it cost $220 to have it done ,$120 of the cost was labor. Now this was done two years ago. If you can find a drive shaft close it sure would save you some money but if you have a driveshaft cut and balanced I am sure the labor cost would be up there.
Good luck Dave | | | | | Joined: Sep 2002 Posts: 438 Shop Shark | | Shop Shark Joined: Sep 2002 Posts: 438 | Dave-
Thanks for the ballpark estimate. With some common shafts possible I'll hopefully just have to pop for the balancing. Thanks! | | | | | Joined: Nov 2001 Posts: 1 Junior Member | | Junior Member Joined: Nov 2001 Posts: 1 | I replaced my stock engine with a 350 chevy out of a camaro. I took my original driveline into the shop had them shorten and balance it, and it only ran $80.00. Works like a charm. Hope this helps.
Darren J. Cannell
| | | | | Joined: Jul 2000 Posts: 619 "MONGO" | | "MONGO" Joined: Jul 2000 Posts: 619 | Just had one made to go on my 53' I was switching from an enclosed driveshaft to a S10 T5 with a monte Carlo Rear end. I bought the S10 driveshaft with the T5 $15 and had it shortened and balended, 1 new yoke to match the Monte Rear and ujoints all for $109 they also cleaned the rust up on it and painted it glossy black for me. Place was Inland Driveline here in KC (I know not much help for you but maybe for someone in my neck of the woods). MONGO | | | | | Joined: Sep 2002 Posts: 438 Shop Shark | | Shop Shark Joined: Sep 2002 Posts: 438 | Mongo-
Thanks for the info. I've been distracted by brakes, but hope to hunt down a stock shaft of length from the bone yards. Balancing is probably still wise. Shiny black paint would also be welcome!
You just keep clicking along all summer long. Way-2-Go! | | |
