1 members (Ole49GMC), 109 guests, and 0 robots.
Topics128,115
Posts1,056,292
Members48,439
#1315371 06/23/2019 8:54 AM
Am thinking of putting one of these transmissions in my truck replacing 3 speed Saginaw any problems I need to overcome I know I’ll have to get rid of three on tree and go to floor shift
I have no particular advice regarding the Tremec but I’ve heard good things. Please tell us more.
What year truck?
What engine?
What kind of clutch release mechanism do you plan to use?
57 3200 with 265 v8 want to use same clutch
Do you know if the Tremec 600 has the same bellhousing bolt pattern as the Saginaw?
Do you have bucket seats? The pics which I have seen show the shifter positioned quite far to the rear. Maybe some of them aren't like that.
Yes I I have bench seat can get a remote kit for gear lever will bolt straight up
TPR57C #1316361 07/03/2019 10:30 AM
I have an S-10 5 speed in my 54 which fits great but the mustang one is too far back. My limited understanding is the Tremec is the same as the S-10 and is used in drag racing.
Ron, The Computer Greek
I love therefore I am.
1954 3100 Chevy truck
2017 Buick Encore
See more pix
TPR57C #1316362 07/03/2019 10:43 AM
Tremec 600 I have found out about is for good enough for drag cars way to fancy for what I want
TPR57C #1316695 07/06/2019 12:30 AM
Yes, the Tremec transmissions have several options for the shifter location. I do believe the kits available to move the shifter to the “mid-shift position” are pretty pricey. Just depends what you want and the application.
