6 members (rfs56trk, Peggy M, Otto Skorzeny, NJC, Forty9, Donf), 62 guests, and 2 robots.
Topics128,023
Posts1,055,370
Members48,420
#1316191 07/01/2019 6:33 PM
can someone tell me wht the two holes approx 3/8 diameter with flat located to the left and right of the radio holes. i believe the left hole is for the ignition. don't have a clue for the right one. thanks for any help.
frank
clrh2ofrank #1316192 07/01/2019 6:41 PM
If you mean 3/4 inch (where the ignition switch goes thru), I believe the one on the right is for an accessory cigarette lighter. On my truck (which didn't have a radio) it had a snap-in plug.
klhansen #1316193 07/01/2019 7:37 PM
There is a 3/4 in hole on to the right of the hole i am talking about. the 3/8 hole is between the right radio hole and the lighter hole which is about 3/4 inch.
thanks
clrh2ofrank #1316194 07/01/2019 7:39 PM
I suppose it could be something that was added. with the flat i did not think it had been added however it could have.
clrh2ofrank #1316195 07/01/2019 7:41 PM
Sir Searchalot
Sir Searchalot
If it's a factory punched out "D" hole, it's not added. Always start with what vehicle you have.
Item 11 is lighter, 10 is throttle, 8 is choke
Interesting info to read
The smaller 3/8 "D" holes holes are usually for push/pull, like the left side choke/throttle. The hole to right of that 3/8 is lighter. That 3/8 is usually plugged.
clrh2ofrank #1316198 07/01/2019 8:03 PM
frank
What make/year/model trucks are being referred-to (in the first post, and in replies)?
1954/55st in bartamos’ reply.
Also the Jim Carter 54/55st two-tone interior color scheme is a little incorrect, I think.
clrh2ofrank #1316202 07/01/2019 8:31 PM
Sir Searchalot
Sir Searchalot
Past posts indicated 1954. Tim is the 54 expert here. Not me.
clrh2ofrank #1316204 07/01/2019 9:09 PM
This is my 54 gmc Canadian model 9300 half ton short box
1954 Canadian GMC 9300
"The Journey"
Follow in the DITY
tclederman #1316238 07/02/2019 2:46 AM
Thanks for the help. The layout is great. I agree that the two D holes are for the throttle and choke. It is a 54 3100. It had a plug in the lighter hole, but i have replaced it with a 12 volt power outlet.
Thanks again for the help. i will be back for more.
Moderated by  ndkid275, Phak1
