1 members (216wny),
158
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,157 Posts1,056,874 Members48,456 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2012 Posts: 124 Shop Shark | | Shop Shark Joined: Apr 2012 Posts: 124 | I was thinking of going to a 292 exhaust manifold and a bigger pipe on my 250 when I rebuild it. How would this compare with fenton headers and dual pipes? It would be cheaper and easier but is there a downside? Would it be compatible with my stock intake? Any advice would be greatly appreciated. Thanks a lot, Gene
Gene 1959 Apache
| | | | | Joined: Feb 2001 Posts: 1,094 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 1,094 | I believe the 292 exhaust manifold is larger. It should match your stock intake manifold. If it's larger it may make some difference from the original manifold, though I doubt you would notice it. You could have your exhaust shop split the pipe with a y and have two pipes at the rear of the truck. I have the fentons on my 261, They don't fit without some grinding and some modification to the clamps that hold it and the intake together.I do at times think about putting the original manifold back on the truck.
Tommy 59 apache 1/2t 261 short stepside | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | The light duty 1/2to 1 ton 250 & 292 use the same size manifolds. The larger truck 292 engines have a larger outlet & it points straight down. It will improve the performance of the 250 but they are hard to find. They have a 2 1/2 in. outlet. George They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Apr 2012 Posts: 124 Shop Shark | | Shop Shark Joined: Apr 2012 Posts: 124 | Thanks for the replies. If I come across one cheap, I will probably get it. I can't hurt but I won't worry about it too much if I can't find one. Thanks again , Gene
Gene 1959 Apache
