6 members (32Fordpuchoptop, Youngin' Tut 59, treegrower, Gray_Ghost, Wickedbass, WICruiser), 66 guests, and 3 robots.
Topics128,076
Posts1,055,922
Members48,430
#1315708 06/26/2019 1:24 AM
1953 3100 with a 216 and SM420.
The truck was disassembled a few years ago and I am unable to locate/identify some of the linkage parts for the accelerator to carburetor.
Also, the linkage between the clutch pedal and fork.
Would someone please be so kind as to post a few photos of these linkages. It would be a great help in locating/identifying the part.
Thank you in advance.
'53 3100 5-window
'57 Mercury Monterey 2-Door Sedan
Tim H
hope this helps
1953 Chevrolet 3100
In the DITY Gallery
Video of the 261 running
1964 GMC 1000
AD Addict & Tinkerer
This is from the Truck Assembly Manual.
Phil
Project Journals
Stovebolt Gallery Forum
I have not been able to locate the accelerator rod that connects to the gas pedal. When the truck was disassembled a few years ago, all small parts were placed in an old filing cabinet, but for some reason it is not there. Ugh!
The manual shows it to be part number 3701623 and a google search returned info that it is 17 3/16 inches long.
Does anyone have a photo of this part? Please share, it may help me locate it.
'53 3100 5-window
Tim H
Here you go. It's a cute little thing.
In the photo, it has an eye on the pedal end. I was under the impression it has a ball on the gas pedal end for a '53 3100.
'53 3100 5-window
Tim H
The pics were from my '51. I don't know if there's a difference, but I doubt it. No need for a ball joint on the pedal, as the pedal's on a pivot to the floor.
[on edit] I looked at the'47-'54 FAM (which is basically a collection of '54 documents) and on Section 6, sheet 3.00, it shows the accelerator rod with a ball fit into a socket on the pedal. That page is dated 5-1-53, so maybe a change was made about that date. My pedal definitely has a pinned joint to the accelerator rod.
'53 used the ball and socket gas pedal. I prefer the '47-'52 pin arrangement. If your linkage/bellcrank gets jammed up with the ball and socket pedal, you can't dig your toe under the gas pedal and free it up. All you do is pop the ball out of the socket.
I guess GM saved a few pennies per truck with the simpler to install on the line, ball and socket design.
Carl
