| | | Forums66 Topics128,037 Posts1,055,463 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | Has anyone looked into using Holley's new TBI fuel injection on a stovebolt? The new computer is much more versatile than the old projection and can be run closed loop and programmed with a laptop. The whole setup is about $1400. You can use it with a turbo, too.
Paint & Body Shop moderator A lone amateur built the Ark. A large group of professionals built the Titanic. | | | | | Joined: Mar 2003 Posts: 23 Junior Member | | Junior Member Joined: Mar 2003 Posts: 23 | Hi, A newbie here. I thought I would give a suggestion I haven't seen here yet. An article in 4 Wheel & Offroad showed a TBI swap on a '70 Toyota FJ40. Now before you start yelling, the straight 6 they use is basically a 235. Turbo City offers the kit minus the distributor. The kit is really a system off a 90's S-10 w/4.3 V6. They got the electronic distributor from Up and Over Innovations which is a modified GM distributor. I haven't researched it much more, but it seems like a cheap swap if you use a donor S-10. You might need the intake off the Toyota or use any 2 barrel intake. The kit has a throttle body to intake adaptor which they might sell seperate. I plan on doing this swap on my '48 after I scrounge up the parts. If anybody wants to see the article, email me & I can fax it to you. If I figure out the scanner I might be able to send it email. I will post more when I get more specific info.
Scooter
I am a total control freak. I shift for myself. No auto's!
1948 1 ton 5 window w/235 1951 1.5 ton dump w/235 1966 3/4 fleetside w/283 1962 Bel Air 235 w/OD & one rusty,beat up,240K mile '82 Chevy 3/4 ton
| | | | | Joined: Apr 2002 Posts: 1,571 Shop Shark | | Shop Shark Joined: Apr 2002 Posts: 1,571 | Build your own! Even if you use one of the fuel injection tuner places to make you a custom chip, the junkyard parts would be a lot cheaper than buying a kit from somebody. There is info all over the web on adapting GM fuel injection systems to all sorts of engines, and TBI systems are a dime a dozen in every junkyard I have ever seen. | | | | | Joined: Mar 2003 Posts: 23 Junior Member | | Junior Member Joined: Mar 2003 Posts: 23 | Yeah, GMCPanel. I meant that I was going to build my own. I can't see paying more than what I paid for my truck for something I can find in salvage yards cheap. I am surprised that I haven't seen any TBI's on this site. Wouldn't it make a great tech article? I can't be the only one who didn't know Toyota used the 235 all through the 70's. It's a good place to look for parts like alternator brackets, distributors, heads, etc. I know I'm checking the yards this weekend. My truck is missing most of the underhood stuff and needs to upgraded to 12v, so it's a perfect time to do TBI. Wonder how many problems I'll run into? I would appreciate any suggestions. Thanks. Scott
Scooter
