1 members (klhansen), 101 guests, and 1 robot.
Topics128,151
Posts1,056,999
Members48,460
Have a 52 Chevy 3100 pickup w/ 4 speed tranny. Has new pressure plate, clutch, & throw-out bearing. After messing with the clutch adjustment, I heard a clunking noise then shifting into 2nd gear but no other gear (engine was off). It would freely shift out of 2nd, but every time shifted back in - "clunk". Rats, after starting engine I shifted into reverse - worked fine. Then went into 2nd, heard clunk. Now it is stuck in 2nd & can't get it out. Did I mess the clutch up? Any help would be appreciated soon, as I am to sell the truck in 2 days & I was just trying to tweak stuff prior to it's sell. Thanks. Bob
Did you take the shifter off of the top of the transmission? If so maybe not aligned right when you put it back.
Tommy
59 apache 1/2t
261 short stepside
Never taken top off.
If the shift lever was removed (not the top of the transmission) it's possible to get the exact symptom you're describing if the shift rails aren't aligned properly when it's re-installed.
Have never taken the shift lever off either. I'm starting to think it may be in the tranny?
Perhaps a broken spring that keeps whichever shift rail in gear.
I’d remove the shift lever (not the whole top yet) and see how it looks in there, even use a big screwdriver and work each shift rail forward and back to see how they feel. Might help to jack up one wheel and have someone slowly turn a wheel while you fiddle with the transmission.
•1952 Chevrolet 3800 pickup
---All pictures---
Yea folks, thanks for the help. It did end up being the shift level. The end had worn down to the point of getting caught between two gears. I had end welded to build it up, then shaped on the grinder - it now works great. Bob
I sure appreciate this forum - and your helping a rookie when it comes to trannys..
I hope you also re-tempered the end of the shift lever after welding and reshaping it. If you left it soft, it's going to be a short-life fix. That stub end of the shifter is harder than woodpecker lips from the factory!
Used in reasonable shape should be easy enough to find.
Or available new.
https://www.novak-adapt.com/catalog/transmission/transmission-parts/sm420-parts/
---All pictures---
