| | | Forums66 Topics128,131 Posts1,056,724 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2010 Posts: 43 Wrench Fetcher | | Wrench Fetcher Joined: May 2010 Posts: 43 | What are you guys running for a gas pedal? My truck still has the original pedal in the floor but the rod or whatever hooked to it is gone. Is there easy parts to use it or is there an easy aftermarket pedal that works good in this truck? Thanks | | | | | Joined: Feb 2016 Posts: 1,994 'Bolter | | 'Bolter Joined: Feb 2016 Posts: 1,994 | Mine still has the original, can't recommend anything other than LoKar stuff.
| | | | | Joined: Jan 2000 Posts: 2,074 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 2,074 | Search Ebay, shouldn't be hard to find part, usually nothing works like the factory parts. Good luck | | | | | Joined: Mar 2004 Posts: 6,225 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,225 | Is your truck a 6-cylinder or V8 model? The linkages are different... Place a wanted ad here on the Bolt...that shouldn't be a hard part to find used. Mike B  | | | | | Joined: May 2010 Posts: 43 Wrench Fetcher | | Wrench Fetcher Joined: May 2010 Posts: 43 | My truck is a 6cy truck. Putting a v8 in. Be nice to keep the factory pedal. I need to try to look up what the linkage looked like. | | | | | Joined: Jul 2016 Posts: 53 'Bolter | | 'Bolter Joined: Jul 2016 Posts: 53 | Hi gear. If I understand correctly, you are looking for the bracket and rod linkage that attaches to the fire wall and connects your existing pedal to the carb. The one for a v8 is different than a v6. The linkages are the same for pick ups because they share the same cab. Pick you favorite aftermarket truck restoration supplier and they should be able to hook you up. I purchased mine from Luttys Chevy Warehouse in Saxonburg Pa. I believe you will find dimples on the firewall where you will need to drill new holes for the v8 bracket if your truck came with a v6 originally.
Rich
68 C30 CST dually flatbed dump 58 Viking 6500
| | | | | Joined: May 2010 Posts: 43 Wrench Fetcher | | Wrench Fetcher Joined: May 2010 Posts: 43 | I will look into that option too. Thanks! | | | | | Joined: Mar 2004 Posts: 6,225 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,225 | | | | | | Joined: May 2010 Posts: 43 Wrench Fetcher | | Wrench Fetcher Joined: May 2010 Posts: 43 | Cool thanks mike. I’d rather stick with stock, probably best anyway. Is there a short cable that runs off that to the carb. Maybe I can find a view of it on lmc or something. | | | | | Joined: Jul 2016 Posts: 53 'Bolter | | 'Bolter Joined: Jul 2016 Posts: 53 | Hi Gear. The linkage in the link that Mike sent you is all you need. It connects to the pedal and directly to the carb. It is a reproduction of the original.
Rich
| | | | | Joined: May 2010 Posts: 43 Wrench Fetcher | | Wrench Fetcher Joined: May 2010 Posts: 43 | | | | | | Joined: May 2010 Posts: 43 Wrench Fetcher | | Wrench Fetcher Joined: May 2010 Posts: 43 | Can this be installed with the motor already in? I wasn’t sure if anything mounted behind the Motor that had to be drilled. | | | | | Joined: Mar 2004 Posts: 6,225 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,225 | Might be a two man job, but I believe you can do it. Drill the two holes just above the gas pedal at the dimple's and bolt it in. If I remember correctly (it's been a few years) I had to take the repro linkage apart and reassemble it as it came wrong from China, so pay attention. Mike B  | | | | | Joined: May 2010 Posts: 43 Wrench Fetcher | | Wrench Fetcher Joined: May 2010 Posts: 43 | Thanks Mike! You are awesome! | | | | | Joined: May 2010 Posts: 43 Wrench Fetcher | | Wrench Fetcher Joined: May 2010 Posts: 43 | I ordered the linkage, should be here Tuesday! | | |
