7 members (32Fordpuchoptop, 3B, TUTS 59, Shardean, msmall, carbking, Bill Hanlon), 51 guests, and 3 robots.
Topics128,030
Posts1,055,430
Members48,422
#1315305 06/22/2019 9:54 PM
What is everyone running as a replacement hose for what appears to be crankcase ventilation and vent off the hydro vac? Looks to be 3/4" id and is a thin wall with a wire spiral in it. The truck is a 56 6500.
ragtopwally #1315372 06/23/2019 10:59 AM
7
7 Offline
I used fuel hose without wire but the section that makes a U-bend kinked. At this point I'm not using the hydrovac so I don't need vacuum to it anyway. I'm not sure if I have all of the hoses routed correctly.
ragtopwally #1315383 06/23/2019 12:42 PM
You can install a "spring" inside the hose, loose fit is fine to ease installation, or outside if your situation dictates. A screen door spring will work and can be stretched to space out the coils. Some tool gypsies sell them, made of soft wire to make stretching easier.
I think this one is meant to go on the outside of the hose:
https://www.aquatuning.us/water-coo...20sZFUDXcaYyrGtRyOq1eO4rl6xoCi3IQAvD_BwE
I am pretty sure that vacuum hose is different from fuel line, rubber wise. It seems to me that use with fuel vapor affects the rubber differently than does liquid. Anyone have the real information on that?
Mac :{)
1962 K10 short step side, much modified for rally
1969 T50 fire truck, almost nos, needs a few things
ragtopwally #1315456 06/24/2019 12:58 AM
Fuel hose is too small for this. It comes off a tee fitting on the oil bath air cleaner and goes down the firewall and right frame rail then crosses over to the left frame rail and then to the vent on the hydrovac. OD of the fittings is 3/4. I’ve seen later trucks use a little breather in the cab corner that the same hose goes to but mine connects to the top of the oil bath.
ragtopwally #1315459 06/24/2019 1:15 AM
Parker makes a variety of "suction" hoses that include an internal wrap (spring) at 3/4" ID. Most of them are nitrile inner hose, which is fine for fuel, oil, etc service. Maybe check in with your local hydraulic hose distributor for something appropriate.
1947 2nd-Series GMC FC152 3/4-ton
Follow the story in the DITY
1953 Chevy Bel Air Sport Coupe Powerglide
