| | | Forums66 Topics128,022 Posts1,055,362 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2019 Posts: 17 New Guy | | New Guy Joined: May 2019 Posts: 17 | Hi: Does disc brake conversion reduces the width of the axle, either front or rear? We know that brake rotors are lot thinner than drums, so I assume converting to a disc brake reduced the width of axles, front or rear. The reason I am asking is I am thinking about swapping my stock HO52 to a 14 bolt out of a one ton van which is about couple of inches wider on each side. The 14 bolt has drums so I am thinking if I swap the 14 bolt to disc brakes, I will be very close to my stock drum HO52?! Am I missing something?
1953 GMC 150: new member 1967 Chevy C20, 4 wheel 8 lug disc, 350 engine with Fitech carb (in progress) , T5 1972 Chevy Nova, 4 door sport sedan in the making  1979 Chevy Camaro Z28, 5,3 Vortec and TH350, 4 wheel disc and Hydroboost; Just about becoming summer daily driver
| | | | | Joined: Apr 2005 Posts: 2,097 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,097 | Disc brakes don't necessarily reduce the overall width. Rotors are either mounted to or are part of a hub which has bearings that are supported on the spindle. The wheel is subsequently mounted to the outside of the hub. To determine the overall width you would need to measure the outside dimension of the hubs on the current axle and the proposed replacement. There can be a lot of variables depending on fender clearances, wheel width, and offset.
Fred.
| | | | | Joined: Apr 2016 Posts: 102 'Bolter | | 'Bolter Joined: Apr 2016 Posts: 102 | Self,
The common term used is WMS, Wheel Mounting Surface. you will need to measure WMS to WMS on both axles and compare. There is a post pinned to the top of the Tons o' fun page that has A LOT of good info on the 14 bolt swap. It will take an hour or so to read...
Jon | | |
