| | | Forums66 Topics128,163 Posts1,057,044 Members48,463 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#13148 07/25/2004 3:59 PM | Joined: Oct 2000 Posts: 244 'Bolter | | 'Bolter Joined: Oct 2000 Posts: 244 | Is there a right way or wrong way to install a new exhaust/intake manifold gasket? Does the shiney side go towards the head or manifold? | | |
#13149 07/25/2004 4:19 PM | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | buckaroo,
It is my recollection that the shiney side of the gasket is away from the head, towards the manifold. If you have a Shop Manual, I recall that it is described there (I am away from home and not near a manual).
Tim | | |
#13150 07/25/2004 7:09 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Yes the matalic side goes toward the manifolds. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
#13151 07/25/2004 9:21 PM | Joined: Mar 2001 Posts: 316 Member | | Member Joined: Mar 2001 Posts: 316 | Don't forget the "alignment sleeves/rings" that go in the registers in the intake ports/heads. Shiny side out on the gaskets.
*** GMC ***
#13152 07/28/2004 4:38 AM | Joined: Nov 2003 Posts: 117 Member | | Member Joined: Nov 2003 Posts: 117 | What about the gasket between the intake and exhaust manifolds? Which way does the shiny side go?
Winona 1949 3100 5 Window Deluxe Cab
#13153 07/28/2004 4:39 AM | Joined: Nov 2003 Posts: 117 Member | | Member Joined: Nov 2003 Posts: 117 | What about the gasket between the intake and exhaust manifolds? Which way does the shiny side go?
#13154 07/31/2004 10:00 PM | Joined: Jul 2004 Posts: 2,991 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 2,991 | Is that what those rings are for-to align it? I just ran into that on an International truck. I forgot to put them in the first time- ended up taking the whole thing back off. Of course, it took a whole lot longer the second time! Had a h--- of a time lining up the back bolt because, of course, I couldn't move the manifold around. Would I have gotten in trouble if I had left them out? Rich | | |
