5 members (Shaffer's1950, Gdads51, Otto Skorzeny, Wayne67vert, Hotrod Lincoln), 96 guests, and 1 robot.
Topics128,139
Posts1,056,454
Members48,441
#1314211 06/13/2019 5:52 PM
S Online: Content
Hello bolters,
I am getting ready to re install the stock gauges. I have the Grommet set. The question is on the throttle/Choke/Oil pressure/Temperature. How is/was the Temperature gauge run through the grommet? My old one was rotten and gone. Do I cut a "Slit" on it to put the line through? I tried looking in my FAM but the pictures are not good.
Thank you in Advance.
1950 Chevy 3100
Not sure how it was done originally, but I did what you said. The end on the temp sender tube ain't going through the grommet. So I slit it and the put a little black weatherstrip adhesive on the slit. You can't tell it and it helps keep the grommet in the hole.
Mike
1951 3100 5 window
I 've got my 54' under plastic masking, but here is a photo of another person's truck and you can see that the originals were "slit" . That what I did when I replaced the grommets on my firewall.
Ron - - Dusty53
1954 Chevy 3604
S Online: Content
Great...once Installed I'll slit the one and put a dab of black adhesive. Thank you very much.
1950 Chevy 3100
Moderated by  ndkid275, Phak1
