8 members (Otto Skorzeny, 68ironhead, 3B, Jon G, Gdads51, NJC, 2 invisible), 104 guests, and 1 robot.
Topics128,130
Posts1,056,369
Members48,441
#131420 09/27/2002 11:02 PM
I just got a rear out of a 76 Nova for my '49. Will it hurt to sand blast it? It look pretty well sealed up dosent look like sand will get in side. Thanks grin
"Finish the thing, do it right the first time, and drive the S.O.B.!"
1949 Chevy half ton 3100 In a kazillion pieces
2000 GMC Serria 1500 SL 4x4
I done a few that way and had no problems. You will want to stay away from the seal at the pinion and axles. Remove the brake drums so you can clean better when you are done. Also, seal the vent tube real good. When you are done blasting, pull the pan and drain the oil real good, and pull the axles out. Hit the car wash and clean inside and out real good. The hot soapy water really does a good job. Take some WD-40 along to coat the gears after washing. Replace the axle seals and add fresh gear oil ( 80-140W ). With fresh paint, you now have one project done and many more to go!!
