Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
1 members (Hotrod Lincoln), 60 guests, and 5 robots.
Topics128,009
Posts1,055,293
Members48,419
#1314059 06/12/2019 5:40 AM
I recently hauled home an orphan 1960 C10. The engine serial number looks kind of odd to me.
In the following picture are the I’s read as 1’s?
Thanks in advance,
To Our Veterans, a Grateful Nation remembers and thanks You!
The casting marks indicate the date. Looks like conveyor #4 and cast on
L=December
19 = 19th day
9 = year but I’m uncertain about what engine you have because of the location of the serial number FI22IJC (both are i). If there is no road draft tube and the fuel pump is to the rear of the engine perch, then I’d guess you have a December 19, 1969 292ci engine.
Got any more pictures?
Lugnutz, thanks for your reply.
This has the road draft tube.
Fuel pump at the front of the engine.
Enclosed an overhead picture.
How do you read the engine serial number?
Is this the correct S/N for a 1960 235 c.i.?
Find the casting number per the link below and tell us what you find.
http://www.1954advance-design.com/Web%20images/casting-code-photos/codes-ser-nums.html
1960 might have had a 235. Your date code L199 might indicate 1959 casting date. But it could be any replacement motor. Show us some more pictures.
Your valve cover have 4 fasteners?
I will move this post to the engine pages where you will get more insight if you dont get answer here.
HB
~ HB
1962 Chevrolet C10
1962 Suburban
Thanks Hambone, it does have 4 screw fasteners on the valve cover. Pretty sure this is a 1960 235. Will need to get to WallyWorld do more engine degreaser to find the block casting numbers. Have gone through 3 cans of degreaser just to uncover what I have found so far.
How to read the engine serial numbers? Read where the suffix JC indicates 1960-1963 engines.
that is the head #. The engine block # will be down by the distributor. xxx848 is desired. Google chevy 6 cylinder engine identification and you will find a number of resources.
Send more pictures of the truck as well. We will get you started.
~ HB
1962 Chevrolet C10
1962 Suburban
If you have not yet ID'd your engine head/block, find/post the codes at the locations shown on this page:
Engine Serial Number
Head date casting code, and head casting code
Block date casting cost, and block casting code
