7 members (60steve, J Lucas, klhansen, greenie-reddy, NJC, TooMany2count, Lightholder's Dad),
130
Mod | | | Forums66 Topics128,277 Posts1,058,451 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2000 Posts: 244 'Bolter | | 'Bolter Joined: Oct 2000 Posts: 244 | I’m installing a new horn in my 1953 GMC and need some help. I tested the horn hooking it to the battery and it works. I checked the wire continuity from the horn to the horn relay and it’s ok. I don’t have a horn button but when I press the horn ring nothing happens. Is there a way to test the horn relay? Does the horn work without the car running or does the key need to be turned on? I’d appreciate any ideas on what to check next. | | | | | Joined: Jan 2002 Posts: 2,853 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,853 | Yes, the horn should work without the truck running.
Craig My '50 Chevy 3100 5 window, '62-235cu, 3:55 rear My truck ....... Respect The Rust If I'm not working on my truck, '65 m00stang or VW camper, I'm fishing with the wife or smoking Salmon.
| | | | | Joined: Feb 2001 Posts: 4,095 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 4,095 | Sorry but I don't know enough to horn in  . I have $300.00 steering wheel and shortly after I got it would blow when I turned the wheel so I re wired it to a separate button. You do it works off ground not a hot wire.
Ron, The Computer Greek I love therefore I am.1954 3100 Chevy truckIn the Gallery 2017 Buick Encore See more pix1960 MGA Roadster Sold 7/18/2017
| | | | | Joined: Jan 2002 Posts: 2,853 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,853 | Did you check the wiring that goes up inside the column? Maybe it's the horn connector and it's spring? Maybe the horn contact plate? So many possibilities,
