1 members (Eisenholtz),
59
Mod | | | Forums66 Topics128,022 Posts1,055,377 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2002 Posts: 2,168 A teacher, but always an apprentice. | | A teacher, but always an apprentice. Joined: Apr 2002 Posts: 2,168 | I was at a local show last weekend and my wife brought along my 1 month old daughter and my, almost two year old, son rode with me in the 1 ton. We parked, entered the truck, and enjoyed most of the morning before the kids got tired and had to head home for lunch and a nap. My wife departed and I had about an hour before I needed to follow her to help with chores and such around the house.
So, I hopped in the truck, with friends watching and saying goodbye, strangers watching “the guy with the 1 ton”, and I stuck in the key and proceeded to turn it over.
Whirrrr, whirrrr, whirrr....nothing! What?! Whirrrr, whirrrr, whirrr...nothing! C’mon! What the?!
Grind...ugh...the one dead spot on the flywheel. UGH!!!!!
By now everyone is watching me and I’m truly embarrassed. I put the truck in gear and touched the starter to help lurch the flywheel into a good spot. Whirr, whirr...nothing...
Arghhh!
“Pop the hood, Fox,” said my friend Barry.
I looked down. I put the key in but failed to turn it on!!
Turned key, kick start...Vrooooom! Like a champ.
So embarrassing! Especially when you’re parked next to a brand new 2019 Dodge Demon muscle car! Funny but not funny!
| | | | | Joined: Aug 2016 Posts: 146 Shop Shark | | Shop Shark Joined: Aug 2016 Posts: 146 | | | | | | Joined: Apr 2005 Posts: 2,832 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,832 | Welcome to the old car world. My 37 Buick has a flip switch on the steering column and you step on the accelerator pedal to start it while my 46 Ford has the column flip switch and a button on the left side of the dash. If my head is out in the ozone for some reason or I have the idiot device (cell phone) pressed against my ear I have pushed the button or stomped the foot feed and cussed them for not starting. A flip of the off-on switch always makes a huge difference.
Evan
| | | | | Joined: Nov 1995 Posts: 5,714 Bond Villain | | Bond Villain Joined: Nov 1995 Posts: 5,714 | Fox ... (sigh) ... okay, now that you've joined the club ... that is something we all (most everyone -- it's never happened to me as far as you know ...) do but *never* admit to. The trick, which you must learn, is to notice and deftly turn the key without drawing any attention to yourself while doing it. And then get the heck out of there before any of your "helpful" friends want to troubleshoot your ignition or fuel system ...  If you'd like, I can delete this thread before too many of your friends see it ....  Oh, and if you have "friends" like mine, the next time your truck won't start after it's been sitting with the group with the hood opened unattended, check two things: 1. Pull the distributor cap and check that the rotor is still there 2. Check the coil to distributor wire to make sure some one hasn't replaced it with a length of vacuum tubing with the correct ends on it ...
~ John A kid raised on Hotwheels, Matchbox and Tonka cannot be reasonably expected to own only one vehicle as an adult. 1949 Chevrolet 3804In the Legacy Gallery | In the Gallery Forum1973 IH 1310 Dump1963 Kaiser M38A12001 International/AmTran RE3000 "Skoolie"2014 Ford E-350 4x4 (Quigley) | | | | | Joined: Jul 2014 Posts: 1,289 Moderator for Tons o' Fun , Co-Moderator Driveline Forum | | Moderator for Tons o' Fun , Co-Moderator Driveline Forum Joined: Jul 2014 Posts: 1,289 | No, no, tell me it ain't so. You have "friends" who love a practical joke?
Ron - - Dusty53 1954 Chevy 3604In the Gallery Forum "You can't dance with the Devil and then wonder why you're still in Hell." "They will forget what you've said, and they will forget what you have done but they will never forget the way you made them feel." | | | | | Joined: Feb 2011 Posts: 583 'Bolter | | 'Bolter Joined: Feb 2011 Posts: 583 | A friend had a 1940 Chevy 1 ton stake that he was having auctioned off. I did some work on it before the auction to get it running. At the auction the auctioneer announces that it is a running truck and he jumps in to demonstrate. Tried for all he was worth to get the key to turn that engine over. No luck. Another friend of mine wanted that truck so he bid on it and got it much cheaper, since it wasn't a running truck. As the auctioneer stepped to the next item in line to auction, I jumped in the truck, turned the key to the on position, pulled out the choke, and hit the foot stomper. Fired right up!!! Oh, the look I got from that auctioneer. Made my day.
Rick
1939 Chevrolet Stake Truck
| | | | | Joined: Sep 2013 Posts: 1,361 'Bolter | | 'Bolter Joined: Sep 2013 Posts: 1,361 | Vacuum line for a coil wire, now that goes too far. Borderline evil. I do however like it, a LOT!
RonR
1951 3600 with Clark flatbed, T5, 4.10 rear 1970 340 Duster 1990 5.0 V8 Miata (1990 Mustang Gt Drivetrain) 1964 CJ5
| | | | | Joined: May 2001 Posts: 1,904 'Bolter | | 'Bolter Joined: May 2001 Posts: 1,904 | This is good stuff!!!!
I once parked my '48 inside the glass shop when I had all my flat glass replaced. They knew about the foot start button but turned the key all the way to the right (off #2). They wore down the battery, recharged it and pushed it outside.
I didn't ask them if they knew it was 6-volts for the charger. 1948 3/4-Ton 5-Window Flatbed Chevrolet 34 Years. Now with a '61 261, 848 head, Rochester Monojet carb, SM420 4-speed, 4.10 rear, dual reservoir MC, Bendix up front, 235/85R16 tires, 12-volt w/alternator, electric wipers and a modern radio in the glove box.
| | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | I refer to the stomp starter on my '38 as my theft deterrent device.
| | | | | Joined: Jun 2010 Posts: 170 'Bolter | | 'Bolter Joined: Jun 2010 Posts: 170 | I did the exact same thing in the Home Depot lot. Fortunately, nobody was nearby to witness my embarrassment. | | | | | Joined: Jul 2014 Posts: 362 'Bolter | | 'Bolter Joined: Jul 2014 Posts: 362 | I did that in my neighborhood once not too long after I'd gotten my truck. It stalled for some reason, I don't remember how/why, but it died a couple of car lengths short of a stop sign. For whatever reason, my instinct was to reach for the key as if I was going to start it. I had switched the key off without realizing it, then remembered that the key doesn't crank it, so I tried stomp-starting it, but it wouldn't fire up. I think I made it as far as opening the hood and removing the air cleaner to see if I had flooded it before I realized my mistake. Fortunately I don't think anyone saw me, unless they were peeking through their blinds from inside the house... | | | | | Joined: Feb 2013 Posts: 613 'Bolter | | 'Bolter Joined: Feb 2013 Posts: 613 | Been there done that, been there done that, been there done that. No it’s not a typo, been there done that  | | | | | Joined: Jun 2001 Posts: 793 Bondo Artiste | | Bondo Artiste Joined: Jun 2001 Posts: 793 | If you haven't done this you don't drive your truck enough.
~ Phillip 1949 GMC Suburban - 10 year project 1952 Pontiac Chieftain Convertible straight 8 hydramatic 1945 GMC half ton truck - Driver- Sold 9-15-25 1946 Chevy COE - SOLD 1-5-26 BUH BYE CHEVY! 1959 GMC Half ton long bed NAPCO | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | I did it once in my 1948 Panel (bought in 1969), that had non-working fuel gauge.
I have never done it in my Suburban (bought in 1972), or other A-D/ND trucks.
Because, when I got the Suburban, I got into the habit of enjoying seeing the fuel gauge needle move before foot-cranking to start (it also became my reminder on how much gas I had). | | | | | Joined: Apr 2002 Posts: 2,168 A teacher, but always an apprentice. | | A teacher, but always an apprentice. Joined: Apr 2002 Posts: 2,168 | I’ve also done it on snowmobiles. Pull, pull, pull, pull...Is the key on? Ugh.😎 | | | | | Joined: Oct 2017 Posts: 214 'Bolter | | 'Bolter Joined: Oct 2017 Posts: 214 | I’ve also done it on snowmobiles. Pull, pull, pull, pull...Is the key on? Ugh.😎 Yup, done it on both the snowmobile and the '53...
1953 Canadian GMC 9314 w/ (factory) Chevy 235
| | | | | Joined: Jan 2002 Posts: 2,839 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,839 | OMG! Been there so many times......
Craig My '50 Chevy 3100 5 window, '62-235cu, 3:55 rear My truck ....... Respect The Rust If I'm not working on my truck, '65 m00stang or VW camper, I'm fishing with the wife or smoking Salmon.
| | | | | Joined: Oct 2014 Posts: 136 Shop Shark | | Shop Shark Joined: Oct 2014 Posts: 136 | I had an old '68 pickup back when I was in High School. One day I pulled into my parking spot at the school, turned off the key and the motor kept running. Turned key on, turned key off, turned key on, turned key off, motor still ran like I was doing nothing. So I ended up putting it in 4th gear, holding the brake and popped the clutch, that killed it.
Later that evening, I investigated the cause of the problem and found it to be the key switch. No matter what position the key was in, the ignition system had power. The only thing that seemed to work on the key was the START position would engage the starter. Having to fix it that night, I identified and cut the wire coming out of the key switch and installed a toggle switch under the dash. So now, to start the truck, I would flip the toggle and then use the key to start it. To kill it, I would reach under the dash and flip the toggle switch.
One several occasions in the years following, I would forget the toggle switch and crank and crank and crank on the engine. Then I would remember the toggle switch. DUH!
'53 3100 5-window '57 Mercury Monterey 2-Door Sedan Tim H
| | | | | Joined: Mar 2010 Posts: 10,270 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,270 | If one is able to play it off as though nothing happened, without anyone noticing, it never happened. Just sayin.' My favorite "out" when someone seems ready to call me out, is to fall back on, "I was cranking the engine without the ignition on in order to increase engine speed without the drag of the incomplete combustion process, so that when I finally do turn the key on, it will start right up." "It is similar in concept to push starting a truck with the clutch pedal depressed, and then popping the clutch once the correct speed is reached." That will work for most, excluding that guy who once witnessed me push starting a truck and I popped the clutch without the ignition on... Carl
