| | | Forums66 Topics128,006 Posts1,055,268 Members48,418 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2014 Posts: 307 'Bolter | | 'Bolter Joined: Aug 2014 Posts: 307 | FYI, my 53 sat for over 2 years. Battery was on tender. Had to use Charger to start engine. Ran around block. Negative cable got hot and fried. Cleaned the connections to frame. Replaced rusty washers and cable. Started right up and cable did not get hot. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | If you put copper-impregnated grease on all the clean/shiny contact areas, it will not rust/corrode any time soon. My cables/connections/6v-battery have remained good for over 14 years). | | | | | Joined: Aug 2014 Posts: 307 'Bolter | | 'Bolter Joined: Aug 2014 Posts: 307 | | | |
