3 members (baldeagle, panic, 1 invisible), 78 guests, and 4 robots.
Topics128,014
Posts1,055,330
Members48,419
#1312860 06/02/2019 2:08 AM
FYI, my 53 sat for over 2 years. Battery was on tender. Had to use Charger to start engine. Ran around block. Negative cable got hot and fried. Cleaned the connections to frame. Replaced rusty washers and cable. Started right up and cable did not get hot.
scottss60 #1312865 06/02/2019 3:10 AM
If you put copper-impregnated grease on all the clean/shiny contact areas, it will not rust/corrode any time soon. My cables/connections/6v-battery have remained good for over 14 years).
scottss60 #1313414 06/06/2019 3:04 PM
THank you very much!
