7 members (WICruiser, 55shaker, Gdads51, Hotrod Lincoln, greenie-reddy, TUTS 59, 1 invisible),
144
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,195 Posts1,057,379 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2014 Posts: 14 New Guy | | New Guy Joined: Jul 2014 Posts: 14 | Hi all how do i go about removing Dually rear brake drum with seized brakes...? | | | | | Joined: Jan 2010 Posts: 120 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 120 | In some order, I suggest Try to unstick the drum by towing the truck. Backwards and forwards. Let the adjusters off if they move. Remove the handbrake cable and tap the levers. possibly loosen the bolts holding the slave cyl and let it drop in a bit? Pound around the outside of the drum shere the shoes contact to pop them off. This will stir up asbestos dust so wear a mask. If the drum rotates you will be able go turn and tap it off.
'47 Canadian RHD 1.5 ton truck
| | | | | Joined: Nov 2014 Posts: 37 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2014 Posts: 37 | Everything that Anyoldiron said...plus maybe some heat.
| | | | | Joined: Nov 2011 Posts: 1,611 'Bolter | | 'Bolter Joined: Nov 2011 Posts: 1,611 | Hi all how do i go about removing Dually rear brake drum with seized brakes...? If the truck has been sitting for a while, the drums can be difficult to remove. Patience is important. Beyond what has already been stated, I have found it helpful to remove the axle shafts and outer wheel bearing. Doing this allows the drum to be shifted laterally which often aids in breaking the corrosion bond between the shoes and drum. Once the drum can be moved, carefully insert 2 prybars 180 degrees from one another in between the drum and backing plate and gently walk the drum outward by alternating pressure incrementally on each pry bar. Once you get the shoes past the ridge on drum edge, it is usually pretty easy. Be careful with the use of big hammers and heat as no parts are readily available in the after market. Make sure you exhaust all efforts to back off the wheel cylinder adjusters and parking brake cable tension first. Good luck! | | | | | Joined: Jul 2014 Posts: 14 New Guy | | New Guy Joined: Jul 2014 Posts: 14 | Thanks All will let you know how We Go..! Was not sure if the drum was part of the hub or individual part..? | | | | | Joined: Aug 2009 Posts: 184 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2009 Posts: 184 | On my '46 1.5ton I took the nuts off the backing plate(split the ones that wouldn't come off) and took the whole assembly off as one piece, shoes, wheel cylinders, and drum together. Once it is off it is an easy matter to disassemble everything with no need to heat or pound on anything. I would be very, very, very careful trying to adjust the brakes off as I destroyed one of the adjusters trying to loosen it. By taking the backing plate off you don't have to try to move anything that is frozen. [IMG]http://i299.photobucket.com/albums/mm311/jungerfrosch/linked/P5234173_zps4f15c799.jpg[IMG]http://i299.photobucket.com/albums/mm311/jungerfrosch/linked/P5234174_zps15ae5ed7.jpg
1946 Chevy OS 1.5ton, 1955 GMC 3100, along with other various IH,Ford,Nash,MGB,.....
| | | | | Joined: Jan 2010 Posts: 120 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 120 | To be clear: I may be wrong about your year, but the on most/all duallys, the hub is "full floating" and the drum wont come off until you remove the axle and bearing retainer nuts. for a serious case, Jungerfrosch has a good way to go. You will still need to remove axle and bearings. Agreed too- the adjusters are not strong and should not be forced. If the slave cylinder caps are frozen then the adjusters wont move them.
| | | | | Joined: Aug 2009 Posts: 184 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2009 Posts: 184 | To be clear: I may be wrong about your year, but the on most/all duallys, the hub is "full floating" and the drum wont come off until you remove the axle and bearing retainer nuts. Yeah, you are right you would need to remove the axle and the bearing retainer nut as they hold the drum/hub on the axle tube. Nothing will go anywhere until you take those off stuck brakes or no stuck brakes. That's the fun of a full floating axle, you have to pull the axle shaft and reset your bearings to even check your brakes. You will also have to unbolt the emergency brake bracket....forgot about that one before. Tad
| | | | | Joined: Jul 2014 Posts: 5 New Guy | | New Guy Joined: Jul 2014 Posts: 5 | Mine was stuck on one side I used loks of pb blast and also used it on the adjuster nuts and started working them back and forth til I could adjust them in , I did twist on adjust ter head off but cleaned every thing up and tack welded it back on with a wire welder , just take ur time | | | | | Joined: Aug 2004 Posts: 242 Shop Shark | | Shop Shark Joined: Aug 2004 Posts: 242 | There are some demountable drums that are held on with 2 countersunks screws onto teh hub, however, if teh drum is stuck, I would do as Pual advised.
John G 1942 G5106 1.5-ton Chevy cargo dump Gallery pageOld Dominion Stovebolt Society T/Sgt. Gott (28 years of service with the USPP) 1940 Chevy G506 4112 cargo dump 1942 Diamond T G509 969A 4 ton wrecker 1942 Ward LaFrance G116 series 2 10 ton wrecker 1944 Ward LaFrance G116 series 5 10 ton wrecker 1931 Ford AA with a WEAVER crane 1944 Sterling HC 165 tractor 1944 Autocar U7144T w/ 10 ton trailer
| | | | | Joined: Jun 2019 Posts: 1 Moderated | | Moderated Joined: Jun 2019 Posts: 1 | Just curious how did you split the nuts on the backing plate that wouldn't come off? My studs/nuts on the backing plate sheared and spin with no room for a nut cutter to split them. | | | | | Joined: Dec 2015 Posts: 2,063 Big Bolt Forum Moderator | | Big Bolt Forum Moderator Joined: Dec 2015 Posts: 2,063 | one thing with big bolts, (1 1/2 ton and larger) the park brake is on the back of the transmission, not in the rear axle so, you don't have to worry about that. | | |
