| | | Forums66 Topics128,051 Posts1,055,710 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2016 Posts: 182 'Bolter | | 'Bolter Joined: Jun 2016 Posts: 182 | Hello bolters, I am trying to start my restored 1950 3100. I get no spark at the plugs. Here's what I know: 1) I have blue spark at points. 2) The coil has been tested and is functioning properly. 3) Wires are good and conduct electricity to plugs. 4) Rotor and cap have been replaced - twice. 5) Points gap is set at .022 6) Spark plugs are gapped at .035 7) Nice blue spark on plug when I connect #1 wire to the coil, ground the plug and open the points.I
All the individual components seem to work but when I put it all together - nothing.
Only thing I haven't tried is a new condenser on the distributor. That's next.
I'm running out of ideas!
Any help out there? Jon
| | | | | Joined: Apr 2005 Posts: 7,440 Bolter | | Bolter Joined: Apr 2005 Posts: 7,440 | Condensers fail at an alarming rate these days. Find NOS or NAPA’s top line condenser. I don’t know if that’s your problem but it’s a simple, quick, inexpensive fix, if it works. ðŸ›
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Condensers failed at an alarming rate back in the late 60s and early 70s (as I sadly recall). | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Are you sure the dist. is turning? Did you test the coil wire. Some of the early resistance wires were just in the coil wire. They failed often. I don't think it would be the cond. if you have spark when you open the points. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Nov 2018 Posts: 122 'Bolter | | 'Bolter Joined: Nov 2018 Posts: 122 | I would check that your rotor center tab is touching the center contact of your cap. Sometimes the metal tab on the rotor just needs to be bent up slightly to make good contact with the cap. Good luck!
Charlie
'51 3100 5-Window (Restomod in progress)
| | | | | Joined: Feb 2011 Posts: 583 'Bolter | | 'Bolter Joined: Feb 2011 Posts: 583 | Where are you in Michigan? I live outside Saline, Michigan. If close enough, I'll come to your place and help.
Rick
1939 Chevrolet Stake Truck
