| | | Forums66 Topics128,113 Posts1,056,612 Members48,450 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2001 Posts: 61 Member | | Member Joined: May 2001 Posts: 61 | I know we all have had this problem at some time in our projects. I bought an S10 4.11 rear end for my 1950 Chevy 1/2 ton (not that it matters). As I was cleaning it up and removing the brake parts (to include the backing plate), I discovered when I try to remove the bolts holding the backplate to the axle flange, the bolt heads broke off (even after liberal doses of penetrating rust killing lubricants). Now, I have the bolt shaft stuck in all four holes. What is your thoughts on the best remedy to remove the bolt shafts? By the way, I do have about 1/2 inch of the shaft sticking out the other side. | | | | | Joined: Jul 2000 Posts: 962 Shop Shark | | Shop Shark Joined: Jul 2000 Posts: 962 | D'oh, not fun. I'd grind the broken ends smooth with the flange. Remove backing plate and you may have a little stub of bolt to grip with vice grips or a pipe wrench. IF that doesn't work, center-punch the grind and drill for the correct size ez-out. If that doesn't work, you may be able to put a small pipe wrench on the 1/2" of stud, and screw it out the back. If that doesn't work, you may have to carefully drill it out, and re-tap with the correct size thread tap.
Hope that rear end has c-clip axles, cuz then at least you could get the axles out to access the damage better.
good luck
chip
Preaching the Hot Rod Gospel according to the 4-stroke apostles:
Suck, Squish, Fire and Fumes
| | | | | Joined: May 2001 Posts: 61 Member | | Member Joined: May 2001 Posts: 61 | I think first I will heat the axle flange with a torch and use vice grips. Maybe even try locally cooling the broken end of the bolt with refrigerant.
Another option might be to drill out the hole and use a bolt and nut instead of just a bolt into the threaded axle flange. | | | | | Joined: Oct 2002 Posts: 43 Junior Member | | Junior Member Joined: Oct 2002 Posts: 43 | one other trick i found is to weld a nut over the shaft. Then while it is still hot from the weld try and unturn the bolt with a socket or wrench. I have had luck with this method. The trick is to get the weld strong enough, get the nut somewhat centred and also not try and weld the nut to anything else but the shaft.  I've had a few shafts keep breaking off more and more with every new nut i welded on till it was flush down to the surrounding plate and i still was able to get it out this way!  | | | | | Joined: Jan 1970 Posts: 365 Shop Shark | | Shop Shark Joined: Jan 1970 Posts: 365 | I have had good luck welding a thick washer to a broken off bolt, then weld a nut to the washer and use the nut to turn out the offending member.
I think this works better because it is easier to get better penetration into the bolt using a washer rather than trying to weld down inside a nut. | | | | | Joined: May 2001 Posts: 61 Member | | Member Joined: May 2001 Posts: 61 | Thanks Carl. I will try that.
Where do I buy a welder? LOL I am kidding. I have a MIG I can get my hands on. | | | | | Joined: May 2001 Posts: 46 Member | | Member Joined: May 2001 Posts: 46 | Its probably too late but have you tried the candle wax trick? Heat the bolt while applying wax to it.The wax will be drawn towards the heat so hopefully you have access to both ends.Then grab it with your vice grips.  | | | | | | Anonymous Unregistered | | Anonymous Unregistered | Richie,
One reason Racecarl's solution works well is that in the process of welding you are heating the carp out of the bolt. Next time you get to taking a bolt out like this you might also just try getting it hot and then quenching it with liberal doses of cold water - this will very likely save you the hassle of dealing with a broken bolt. | | | | | Joined: Nov 2001 Posts: 481 Shop Shark | | Shop Shark Joined: Nov 2001 Posts: 481 | Heating the bolt til the center just becomes molten or ready to weld to and then quenching with water does the trick. | | |
