1 members (Hotrod Lincoln), 104 guests, and 2 robots.
Topics128,089
Posts1,056,004
Members48,430
#1312014 05/26/2019 7:06 PM
I have a chance to save a Chevy 4 speed with PTO and brownie from the scrap yard. Is it worth saving? Seems to be in good shape. I have to buy it buy the pound.
Crusing in the Passing Lane
420 or 465? Both are worth saving, can always part them out. Label that PTO if you remove it from the trans.
Ed
Does the Brownie Box come with the shift linkage?
What vintage is the trans???
Old iron is always worth saving as they don't make it anymore...
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
EdPruss #1312059 05/27/2019 5:06 AM
I am not sure what a 420 or a 465 is. Oldest I have dealt with is a 1941 5 speed Clark. The Brownie does come with shifter. I opened it up and everthing looked good, no rust and shifted just fine. I will be picking it up on Tuesday and I will check casting dates then.
I might be interested in a Brownie with overdrive, if it was heavy enough for my 3 ton.
Are you selling this?
~Charley
1954 Chevy 3100 with 235
“Bud”
Follow along in the DITY
1963 Chevy half ton stepside short box 230
1954 GMC 3 ton 302
And several more Chevy camper and work trucks 1979 1987 1996
The brownie that is attached to this 4 speed is a 2 speed Brownie. Direct and underdrive. No overdrive. I do have a Brownie listed on the site everyone loves to hate, that does have overdrive. It came out of a International R-190. It is a Spicer Brown Lipe 6231 which has a .69 overdrive.
Buying or selling should be conducted by PM or in the Swap Meet Forum. Thanks
Alright! Busted.😁
~Charley
“Bud”
1954 GMC 3 ton 302
Well I picked it up and it looks like it is a Feb 1944, 4 speed. Though the 2 speed Warford brownie turned out to have a last patent date of 1926.
