| | | Forums66 Topics128,090 Posts1,056,026 Members48,432 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2017 Posts: 23 'Bolter | | 'Bolter Joined: Sep 2017 Posts: 23 | I have a chance to save a Chevy 4 speed with PTO and brownie from the scrap yard. Is it worth saving? Seems to be in good shape. I have to buy it buy the pound. | | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | 420 or 465? Both are worth saving, can always part them out. Label that PTO if you remove it from the trans.
Ed
| | | | | Joined: Mar 2004 Posts: 6,214 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,214 | Does the Brownie Box come with the shift linkage? What vintage is the trans??? Old iron is always worth saving as they don't make it anymore... Mike B  | | | | | Joined: Sep 2017 Posts: 23 'Bolter | | 'Bolter Joined: Sep 2017 Posts: 23 | I am not sure what a 420 or a 465 is. Oldest I have dealt with is a 1941 5 speed Clark. The Brownie does come with shifter. I opened it up and everthing looked good, no rust and shifted just fine. I will be picking it up on Tuesday and I will check casting dates then. | | | | | Joined: Jul 2018 Posts: 270 'Bolter | | 'Bolter Joined: Jul 2018 Posts: 270 | I might be interested in a Brownie with overdrive, if it was heavy enough for my 3 ton. Are you selling this?
~Charley 1954 Chevy 3100 with 235“Bud”Follow along in the DITY1963 Chevy half ton stepside short box 230 1954 GMC 3 ton 302 And several more Chevy camper and work trucks 1979 1987 1996 | | | | | Joined: Sep 2017 Posts: 23 'Bolter | | 'Bolter Joined: Sep 2017 Posts: 23 | The brownie that is attached to this 4 speed is a 2 speed Brownie. Direct and underdrive. No overdrive. I do have a Brownie listed on the site everyone loves to hate, that does have overdrive. It came out of a International R-190. It is a Spicer Brown Lipe 6231 which has a .69 overdrive.
| | | | | Joined: Apr 2005 Posts: 7,440 Bolter | | Bolter Joined: Apr 2005 Posts: 7,440 | Buying or selling should be conducted by PM or in the Swap Meet Forum. Thanks
~Charley 1954 Chevy 3100 with 235“Bud”Follow along in the DITY1963 Chevy half ton stepside short box 230 1954 GMC 3 ton 302 And several more Chevy camper and work trucks 1979 1987 1996 | | | | | Joined: Sep 2017 Posts: 23 'Bolter | | 'Bolter Joined: Sep 2017 Posts: 23 | Well I picked it up and it looks like it is a Feb 1944, 4 speed. Though the 2 speed Warford brownie turned out to have a last patent date of 1926.
