1 members (Hotrod Lincoln), 104 guests, and 2 robots.
Topics128,089
Posts1,056,004
Members48,430
#131196 07/15/2002 1:17 AM
Junior Member
Junior Member
I'm getting ready to put a GM rear open rear axle with camaro leaf springs under the rear of my 50 1/2 ton. How much should I move the axle to get the tire centered in the wheel well? It looks like about 3/4" back, but I have measured 3 or4 wheel bases on modified trucks that all look centered and lowered and have measured 116.5,117.5,119.5(prostreet)& 114. Stock is 116, what gives? If they all start out at 116 how can all look centered? The front should be all in same location. Sould I just set it close and wait until I get the bed back on? Think the factory set up varied in the wheel well that much? Thanks,
Roy
#131197 07/15/2002 5:31 AM
Fox Offline
Truckeroy, I have a 50 as well. The stock measurement is 116. I asked the same question a couple months ago, the reply said that you have to move it back about 1 to 1.5 inches. Don't worry nobody will even notice.
1970 Chevrolet C10
1950 Chevrolet 1-Ton Dually
"Ole Red Girl"
More pictures here
Parts trucks-
#131198 07/17/2002 1:49 AM
Junior Member
Junior Member
Thanks for the reply. I just measured mine real close and it looks like moving it back 1" is about right. Thanks again.
Roy
#131199 07/17/2002 7:19 AM
truckeroy,
I think the major confusion over where to place the rear axle on 1/2 ton AD trucks comes from the spring center bolt being 1-3/4" forward of the axle center line in the stock configuration. The u-bolts hold a bracket containing a rubber bushing similar to the end of a leaf spring. A matching bracket is then welded to the front of the axle and a thru bolt clamps the bracket to both ends of the bushing.
When I first converted my '49 to a newer rear end, I made up a couple of saddles from 2" x 4" 1/8 wall steel tubing and just drilled the hole for the center bolt 1-3/4" forward of the axle center.
If you have a service manual, there is a picture of the rear spring seat in the rear axle section.
'38 Chevy 1-1/2 ton
'49 Chevy 1/2 ton
'54 Chevy 6400 2 ton
'55.2 GMC 3/4 ton
'56 GMC 1-ton
No Room Left in Shop
#131200 07/19/2002 1:27 AM
Junior Member
Junior Member
thanks for the reply. I am putting a set of camaro springs under and moving the axle back approx 1" to 117" wb. This seems to be about right for my truck.
#131201 07/20/2002 3:02 AM
Anonymous
Unregistered
Anonymous
Unregistered
If you save the spring to axle brackets from an old torque tube rear end all you have to do is cut them off the old axle & weld them on to the new axle. Everthing lines up great then.
