3 members (klhansen, Nick in Manitou, UtahYork), 82 guests, and 4 robots.
Topics128,080
Posts1,055,953
Members48,430
#1311839 05/24/2019 7:54 PM
Does any one know if there are differences in the axles on the outside of the rear axle casting my 54 has a axle from a 51 both are Canadian models .Would like to find out if a American made truck has any markings different so one could tell . I am trying to find out if one could see the difference as I have a spare rear axle and the spare looks different has 3 lines on one of the sides .I am inquiring because I am thinking again of changing to the 355 gears and the Canadian models need a carrier from a American truck as they are different.
1954 Canadian GMC 9300
"The Journey"
Follow in the DITY
KEVINSKI #1311842 05/24/2019 9:19 PM
Do you mean the axle housing or axleshafts?
1953 Canadian GMC 9314 w/ (factory) Chevy 235
KEVINSKI #1311852 05/24/2019 11:49 PM
The housing ,I have a spare rear axle and torque tube that had bendix brakes and I noticed three lines on the housing of the pumpkin can’t remember which side it is on as it is stored but was thinking if there were casting marked on the axle to identify were it was made . I will have to dig it out and take the cover off .Once I have the cover off how would you be able to tell what type of carrier it is.
"The Journey"
Follow in the DITY
KEVINSKI #1311856 05/25/2019 12:23 AM
I’m not sure, mine should be Canadian. I have a few axle shafts I could check, that’s why I asked.
KEVINSKI #1311857 05/25/2019 12:35 AM
From what I found out the carrier is different on the Canadian models so if you want to change the gears to 355 ratio you need to use a carrier from a US built truck.I was curious about the casting marks as my spare unit came from a unknown truck and was wondering if you can spot the difference without taking things apart.
"The Journey"
Follow in the DITY
KEVINSKI #1311903 05/25/2019 2:32 PM
I’ve heard that as well.
KEVINSKI #1311995 05/26/2019 2:28 PM
Fox Offline
https://www.classicparts.com/mobile/1941-54-Rear-End-Gears/productinfo/93-511/
The bottom of the item ad say US trucks only. That must mean CDN trucks are out.
1970 Chevrolet C10
1950 Chevrolet 1-Ton Dually
"Ole Red Girl"
More pictures here
Parts trucks-
Fox #1312006 05/26/2019 4:27 PM
I think he’s aware of that. He’s trying to identify his other axle without taking it apart.
