6 members (klhansen, Tom McGrath, Shaffer's1950, David Bush, Hotrod Lincoln, JW51), 82 guests, and 0 robots.
Topics128,051
Posts1,055,735
#131175 02/06/2003 12:13 AM
I want to add a brake booster to Pops.
Now it's got a hanging pedal setup from a '73 chev pu and stopping quickly can make certain parts of my anatomy speed up and other parts clench. Question is- do I need to change the MC?
What do I look for for parts besides the booster?
Is there a choice as to the size?- I don't really want to want to sound like a novice ...
OOPS! too late!
longtrail
It is only possible to live happily ever after one day at a time.
#131176 02/07/2003 6:00 AM
Master cylinders are specific to application........ manual ones are different than power ones. Yes, you should swap it over, make sure it's correct for your brake system design (disc/drum, drum/drum, disc/disc).
Hopefully you braced the firewall already to reduce flexing/cracking.
You may need different pushrod and mounting brackets, depends on what you have now.
It's pretty easy swap! grin
John Kennedy
1950 Suburban street rod
Pics in the Gallery.......
new site up!
http://home.joimail.com/~kennedyjp/
#131177 02/08/2003 2:22 AM
Thanks- that's about what I figured. will check for new/rebuilt parts for same year but with pb.
So far Ive replaced all brake components - just want the pedal to feel more like my other vehicles.
Yes, I did brace the firewall and dash.
Thanks again
longtrail
