3 members (Lightholder's Dad, Charles in CA, Philipj), 63 guests, and 2 robots.
Topics128,154
Posts1,056,838
Members48,456
I am installing a 292 with a T5 into my 1950 using a 1956 bell housing and cross member and cant find any pictures on the hardware that fastens the rubber mount together. I have found the rubber mounts for sale but no hardware. If someone could provide some info or some detail on this I would appreciate it.
Dongray
1950 Chevrolet 1/2-Ton 3100
How are you attaching the 56 235 bell housing to the 292 block? That bell housing will not bolt directly to a later 292 Chevy block. I wish it did truth be told.
Mike
I'm using a newer 1956+ bell housing which directly attaches to the 292 engine and the T 5 transmission.
Could you post a photo of your bell housing?
Mike
Must be using a bell housing for a v8.
Tommy
59 apache 1/2t
261 short stepside
Here you go Mike,
The original bell housing is flat where it mates to the crossmember where as this one is angled so in order to use it I will be replacing the crossmember as well. I need to do this because the original bell housing wont mate up to the 292 engine so it is driving me to a couple of modifications.
Dongray;
Here is a picture of a TriFive passenger car rear mount. Have you thought about using the rear mount on the T5 since you are building cross members?
SimS
The components for the rear mount consist of the upper and lower mount, a 1/2" x 4" NC bolt, a steel sleeve, and a retainer that has a bend over tab. The mounts and the bolts are available through several aftermarket sources, the sleeves and retainers are not. The sleeves could possibly be made from a short piece of pipe, the retainers could also be fabricated.
Fred
The bell housing in the picture is a for a truck, it only has one bolt holding it to the mount.
Tommy
59 apache 1/2t
261 short stepside
Riding in the Passing Lane
Classic Parts has the complete mount set for that. It has the mounts, bolts, spacers, & lock tab in a kit.
George
1972 Chevy c10 Cheyenne Super
Hey Thanks George, I ordered one up and it fits perfectly!
