5 members (32Fordpuchoptop, treegrower, Jon G, Danielbolt, 1 invisible), 194 guests, and 3 robots.
Topics128,078
Posts1,056,053
Members48,433
#1311437 05/21/2019 9:01 PM
I could use some help ID'ing the the transmission in my 70 GMC half ton. I need to get a seal kit for it. It's a stock 3 speed manual mated to the original 307. The casting numbers are a little hard to read on the LH side but appear to be like 3862845. The RH side 8825647.
Thanks for the help.
1949 Chevy 3600
1975 W-25 Hurst Olds
1970 GMC 1/2 ton Fleetside
2010 Chevy Silverado
It's probably a Saginaw. How many bolts are there holding the side cover onto the case? Saginaw 3 speeds have 7 bolts, and Muncie SM 318's have 4 bolts. By 1970, I'm pretty sure all the 3 speeds were Saginaw.
Crusing in the Passing Lane
One can always carefully remove the seals and get the PN off them.
Ed
Well it has 7 bolts making it a Saginaw. I see Rock Auto has seal/gasket/bearing kits for it for about 90 bucks. My own stupid fault. I'm restoring the truck and had it disassembled down to nothing but the cab on the frame. The trans was working fine so I left it as is other than a new clutch, flywheel, and throw out bearing. I didn't stop to think about the fact the truck had been sitting for years. After about 50 miles of shakedown driving the old dried front seal is now leaking......now that the truck is 95% complete......argh....
1949 Chevy 3600
